Author Topic: Removing paint from tank  (Read 2335 times)
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« on: March 31, 2016, 09:20:00 AM »
Is it safe to use a wire cup brush or wheel brush in a mini-grinder on these tanks to remove all the old paint (and prev PO horrible paint job)?
Or should I use chemical strippers?
--Evan
1975 CB750K "Rhonda"
Offline nvr2old
Re: Removing paint from tank
« Reply #1 on: March 31, 2016, 09:23:42 AM »
Go with the chemical stripper.  Aircraft quality.  Make sure you use heavy duty gloves and eye protection, it's very caustic, and burns like hell if it gets on you.  It'll remove the paint in just a couple of applications, though.
'76 CB550F-'72 XL250-'82 MB5-'82 CX500 Turbo-'77 naked Goldwing-'75 CB400F cafe'-'79 Suzuki GS1000S..hey, it's a Wes Cooley..
Offline Chachi
« Reply #2 on: March 31, 2016, 10:23:10 AM »
Aircraft stripper, something like this:
http://www.kleanstrip.com/product/aircraft-paint-remover
Here's a post on bare metal if you're going that route, treat with Boesheild T-9 after:
http://www.chinonthetank.com/2010/02/bare-metal-tank/
Or clear powder or color powder or repaint, etc.
73 CB750 K3
72 CB500 K1 - Sold
75 MR50 Elsinore K1
« Reply #3 on: March 31, 2016, 10:29:05 AM »
i used the CitriStrip orange stuff....worked great
Offline edwardmorris
  • Youngish
« Reply #4 on: March 31, 2016, 11:28:58 AM »
Rustoleum Aircraft Remover works wonders, even tears through powder coat, but you'll need to be outside to use it on a large item. 1 or 2 applications depending on how bad the old crud is. Fat gloves, breathing mask, and definitely outside only.
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #5 on: March 31, 2016, 02:10:18 PM »
The paint remover in a spray can from Home Depot worked really fast on my last tank. Took everything down to the metal.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline Steve_K
« Reply #6 on: March 31, 2016, 02:15:06 PM »
I had a custom painted tank with bondo showing.  I used a heat gun and removed the paint and the bondo with a scraper.  Worked well and was easy.  I suggest using that method with plenty of fresh air.
I don't know how that would work on original paint.
Steve
Steve_K
« Reply #7 on: March 31, 2016, 02:28:59 PM »
One old school trick that auto body guys used it to put Saran wrap on to of the stripper. It slows down the evaporation and makes it strip better.
Offline Powderman
« Reply #8 on: March 31, 2016, 04:20:45 PM »
I'm still wondering why they call it "Aircraft Stripper"? Ever read the directions on "Aircraft Stripper"? All of them say "Do Not Use On Aircraft".
Offline Kenzo
« Reply #9 on: March 31, 2016, 04:55:47 PM »
H-Town, Tejas
>1976 CB550F SuperSport (Work In Progress)
MotoGP Werks Exhaust, Uni Pods
>2006 KTM EXC 453 (EXC 400 w/ Short Stroke Big Bore Kit)
Offline mystic_1
  • 1970 CB750K
« Reply #10 on: March 31, 2016, 05:59:39 PM »
Mmmm, tailwind.
If you use aircraft stripper, double-glove.  It'll eat through the first pair pretty quickly.  If you get it on your skin, rinse it off immediately with lots of water.
Once the aircraft stripper has done it's work, I like to scrape off the paint with a putty knife.  If you time it right you'll get down to bare metal immediately.  If you leave it too long, the paint will harden back up a bit again.
mystic_1
- John Augustus Shedd
« Reply #11 on: March 31, 2016, 06:49:42 PM »
  I owned a furniture refinishing biz at one time back in the day when you could get the good stuff, and I still can. Everything has a skull and a cross bone on it and I am glad I am still alive. I do "Love the smell of Lacquer in the Morning" though out of my spray guns  ;D ;D
« Reply #12 on: March 31, 2016, 08:01:51 PM »
I prefer the aroma of two stroke in the mornin!
Offline AlekStooge
  • can't afford cheap stuff
« Reply #13 on: March 31, 2016, 08:41:11 PM »
I did the bare metal route with a wire wheel on an angle grinder. Then polish and clear powder. Powder coater disappointed me and I'll need to get it redone :(.Needless to say I won't be visiting him again >:( I rest my case.
One warning if you take this route don't go over the flip style gas cap with the wire wheel. It broke the lock :-[. Take the cap off and do it separately. I prefer this over using chemicals. Here is the result.
Offline calj737
  • I refuse...
« Reply #14 on: April 01, 2016, 04:54:23 AM »
Chemical strip. No easier way. If you want a completely inexpensive method, make a DIY lye bath. Immerse the tank, then voilá! Bare metal, no distortion, no scrape marks, and perfectly clean inside and out.
Offline Bodi
« Reply #15 on: April 01, 2016, 11:10:26 AM »
Lye is good for steel, but take care on aluminum or aluminum alloy. It eats the metal and bubbles off hydrogen gas.
