Author Topic: Caliper bracket bolt removal?  (Read 1812 times)
Offline -JP-
« on: April 01, 2016, 06:13:14 AM »
Hello everybody,
Just a quick introduction because this is my first post. Last month I bought CB750 k5. Well it was documented 75, but after research I found out that it has k3 engine, k2 frame and those early forks (69-72?). Now I`m rebuilding the forks and polishing some aluminum parts. My question is: Is it possible to remove the bolt/pin in the caliper bracket? It would be easier to polish if I could have two separate pieces. I tried to tap it out after soaking it in WD-40. No success. Won`t even budge. Any tips?
Bolt is number 14:
Offline rddcw
Re: Caliper bracket bolt removal?
« Reply #1 on: April 02, 2016, 05:38:11 PM »
Heat and Kroil Oil .
Offline riverfever
« Reply #2 on: April 02, 2016, 06:08:08 PM »
I soaked mine a bit with some PB Blaster and it came out fine.
Offline CB650CPastor
« Reply #3 on: April 02, 2016, 06:18:21 PM »
You haven't hit it hard enough yet.
Tim
Current:1980 Honda CB650C Custom, 1969 Toyota Corona Deluxe Sedan
Past: '07 Honda Rebel 250, '80 Yamaha XS1100 Special, '69 Honda CB160, '67 K15 Suzuki Hillbilly, 1971 VW Super Beetle...
« Reply #4 on: April 02, 2016, 06:22:59 PM »
Have you removed the cotter pin that holds it in place? part #34.
« Reply #5 on: April 03, 2016, 06:38:49 AM »
 Definitely try and get it out and lube it on installation as that joint is critical for its function.
Offline mystic_1
  • 1970 CB750K
« Reply #6 on: April 03, 2016, 09:01:17 AM »
This would be my guess, make sure that cotter pin is out.
Also, do NOT break #4.
mystic_1
- John Augustus Shedd
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=82p3mcdh6s4ncjfe7as3aahvo2&/topic,60973.0.html
« Reply #7 on: April 03, 2016, 11:43:42 AM »
the other( 400/ 500/550) type use pos 15 dont have any Lock pin?? right
i hate all this v-w.... vords
Offline Henning
« Reply #8 on: April 03, 2016, 11:55:30 AM »
Had to use a hydraulic press to get mine out - it was seriously stuck and using a bigger hammer would just have damaged the assembly. Luckily I had access to one at work.
The pin (14) should be a press fit into bracket 4 so there is no movement between them, and the arm (12) moves on the pin. What happens is that the pin rusts solidly to the arm and the movement happens between the pin and bracket 4, buggering up the bracket.
71 or thereabouts 750 K1 - this one should have been put down
Offline -JP-
« Reply #9 on: April 05, 2016, 06:38:26 AM »
Thank you all for replies. Yes, I removed the pin. I already hammered it so hard that I`m affraid that next step might be damaged part. Hydraulic press would be nice. Will try to heat it up.
Offline greenjeans
  • 1972 CB750K2
« Reply #10 on: April 05, 2016, 06:48:22 AM »
Hard to beat a good heat gun and PB blaster.  HEAT.
