If it's going to be a resto-mod, then I would recommend a modern USD fork swap. Buy an entire front from a mid-2000s GSXR (triple trees, forks, brakes, calipers, rotors, axle, and even the wheel if you like the forged style wheel). You will only need to modify the steering stem -- press it out and press in a 750-length stem. If you want spoke wheels, you can buy a new hub from Cognitomoto.com and relace to a rim and bolt on the modern rotors (the hubs are spaced to match the rotors). You can buy a front end cheapest from a motorcycle wrecking yard, second cheapest from craigslist, third cheapest from ebay, and maybe somewhere in between there from the classifieds here.
For instance, I am selling forks and brakes from a 2007 GSXR600 in the classifieds.
