Author Topic: 1974 CB750K float needle wear  (Read 1136 times)
Offline RockVegas
« on: April 05, 2016, 07:38:57 AM »
Can i buff these back to useable or is it immediate replacement?
Sent from my VS985 4G using Tapatalk
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
Re: 1974 CB750K float needle wear
« Reply #1 on: April 05, 2016, 07:42:59 AM »
As long as they are sealing, why worry?
Also at such an inexpensive part... just replace.
Be sure to do a clear tube level check once re-assembled.
--Evan
1975 CB750K "Rhonda"
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #2 on: April 05, 2016, 08:52:19 AM »
+1
Be sure to use Honda parts, or you will be doing it again sooner than later:
http://www.partzilla.com/parts/detail/honda/HP-16011-375-004.html?gclid=CLe5yoDt98sCFVA8gQodS94ONg
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
