Author Topic: First build: CB750 K3 cafe  (Read 21349 times)
Offline -JP-
Re: First build: CB750 K3 cafe
« Reply #25 on: April 29, 2016, 05:37:32 AM »
Before I start the carb rebuild I disassembled the master cylinder. It was a pain, but eventually I got that circlip out and all fell apart.
I couldn`t remove the reservoir from the master cylinder. Is it removable? Is there threads or should I just pop it out somehow?
-JP-
Offline -JP-
« Reply #26 on: May 11, 2016, 11:14:32 PM »
Carbs were sent today to ultrasonic wash. I finally received progressive springs so I could start to assemble the forks. I had to buy a spesific tool for the fork seals, because I have those early internals. I think the fork legs are newer model tough. I also had a set back with the painted parts. Received them, but the paint job was unacceptable. Well the paint job was fine, but the parts were scratched. So I took them back. Maybe I should be painting these parts myself. At least then there is only me to blame if things go bad. So I can`t assemble the triple yet. But some progress was achieved.
There was a little problem with the seals. I had to double check which side goes up. I hope I made the right choise when I put these in text and number side facing up. Larger cavity in the seal was facing down. So the little ridge on the outer side was down. (In the Hack-A-Week series Dino installed these the opposite side facing up. That was a little confusing, because a lot of things I know about this bike I learned from his videos. Or this forum.)
I also honed the master cylinder and installed bearing races for steering head.
I didn`t have the time to ask why my dad wanted these of. Well, those have to be opened eventually. Pipe pliers, heat, tapping, penetrating oil and brutal force did the trick. As you can see the part is destroyed. There is still 4 of these to go.
-JP-
Offline -JP-
« Reply #27 on: June 01, 2016, 11:55:15 AM »
It`s been a while, but today I got the carbs together. I went with 115 main jet and put the e-clip in the middle position on the needle. I hope I get the carbs back on the bike tomorrow.
-JP-
Offline -JP-
« Reply #28 on: June 13, 2016, 10:14:58 AM »
I`m trying to finish these carbs, but I came up with a question. There are 4 small washers/spacers that I`m not sure where they came from. I think these were in the linkage like the picture shows. I can`t find a diagram where these are pictured. If somebody would clarify this it would be appreciated.
And here you can see this spacer between the surfaces that clamp on the rod. The bolt goes thru it. Should it be like this?
-JP-
Offline -JP-
« Reply #29 on: June 22, 2016, 11:29:42 AM »
Some progress here. I managed to assemble the airbox with the K&N filter. Also I got carbs back in to the bike. Front brake is also in place with new hoses. I went with the oem rubber ones. Maybe not the best performance but I like the look of them. Upper hose was a little pain, because Honda doesn`t make that as short as the old one anymore. This new one is about 10cm longer, but it fits ok without any sharp corners. Meters are in place and the instrument cluster. New cables for the speedo and rpm meters also. Feeling hopeful and looking forward to get it on the road in the couple of weeks.
-JP-
« Reply #30 on: June 22, 2016, 11:31:43 AM »
Looking good.
Offline -JP-
« Reply #31 on: July 04, 2016, 12:57:45 PM »
Today I bleeded the front brake and mounted the exhaust. Tomorrow I will receive a new headlight and miscellaneous stuff for it. I`m still waiting carbtune to arrive so I could finally get those carbs synced. I`m having a little issue thats new. I don`t know what is the cause but it keeps burning the main fuse everytime I turn key to ignition. Maybe it has something to do with the headlight section. Electric stuff is another "dark zone" to me so this one can be a pain. I assume the wiring harness and all the other electric components are 40 years old so this didn`t suprise me. I will be getting a new harness and other vital electric components next winter. It will take maybe a week or two to get this thing on the road if everything goes smoothly. If...
-JP-
Offline -JP-
« Reply #32 on: July 05, 2016, 12:31:01 AM »
There is no headlight attached at the moment. Maybe this is the reason? Does the headlight have vital ground points or something that can cause this? My experiences are only with the newer sportbikes that don't need to have headlight attached to run.
« Last Edit: November 27, 2018, 11:28:12 AM by -JP- »
Offline -JP-
« Reply #33 on: July 05, 2016, 01:52:00 PM »
Todays work:
Installed the headlight and turn signals. Checked all the connections in the headlight housing and the fuse didn't burn. And then I tried to start the thing and it started! Great moment indeed. Made me smile. And made my day.
-JP-
Offline mannydantyla
    • dannix.net
« Reply #34 on: July 06, 2016, 08:28:02 AM »
subscribed!
Offline -JP-
« Reply #35 on: July 08, 2016, 09:02:28 AM »
I had some set backs yesterday. I mounted the airbox and was going to tune the carbs with carbtune, but the damn thing fired only one cylinder. I checked the plugs. Good spark in everyone. Gets gas. Points are checked. Battery is full. I don't know what is wrong here. Maybe something with the wiring harness/contacts, I don't know...Little frustration stepping in. It ran fine two days ago. Didn't do anything to it in between. Only moved it. Didn't start it. That makes me think that maybe there is still a bad connection in the harness. I was thinking if I upgrade all the electric stuff. It won't be cheap but atleast it's then done. But will it change a thing? This stuff is going to be upgraded in near future nevertheless. But it takes time to get this stuff here up north and the summer is short.
Made this invention to get this carbtune screw in the middle carbs. Worked incredibly well. My moment of pride before all went south.
-JP-
« Last Edit: July 08, 2016, 09:04:10 AM by -JP- »
Offline -JP-
« Reply #36 on: July 08, 2016, 09:44:57 AM »
You either don't have spark or aren't getting fuel to the plugs. Can't be both are right and you aren't firing. (Technically it could, but given the bike ran a day ago, that rules out the other "possibilities").
When you pulled the plug to check spark, where the plugs clean and wet, or dry and tan?
BTW, have you checked your fuel level too?
Clean and wet.
Well the fuel tank is off so i have a clear long hose doing it's job at the moment. There was fuel in the hose.
« Last Edit: July 08, 2016, 09:47:43 AM by -JP- »
Offline -JP-
« Reply #37 on: July 08, 2016, 09:58:36 AM »
Ok. Thanks a lot. I checked the spark and it was ok. Little bit strange that there is none after I put the plugs in place. Cylinders 2-3-4 didn't fire. Any ideas what could cause something like this?
Offline -JP-
« Reply #38 on: July 15, 2016, 01:03:57 PM »
Until the new wiring harness and coils and stuff arrive I have been thinking the final color of the bike. A lot. As I told I am building this bike with my father and he would like to go with red. We have had a couple of debates about this because I would like to go with flake sunrise orange. Well at least that was the color I was thinking the most. One thing that I`m sure it has to be one of Honda's original colors. The old man didn`t disagree on this one so I`ve been looking endless amount of pictures of these bikes. There were 3 colors in the final. Flake sunrise orange, candy ruby red and candy antares red. I decided to give my father some slack and went with the candy antares red tank and cover set from Yamiya. My fathers birthday is right around the corner so this one will be his present. It better be a pleasant one.
I contacted Yamiya and asked if I could get some pictures taken from the tank in daylight before I purchase. I did. It looks just amazing. After these pictures it was an easy decision.
-JP-
« Reply #39 on: July 15, 2016, 06:28:40 PM »
That color is pretty spectacular.  They have a decent painter.
Offline -JP-
« Reply #40 on: July 20, 2016, 12:09:47 PM »
Not a great day. UPS #$%*ed up my tank. I didn't check the package when I got it. I was in a hurry and damn. Trying to call them tomorrow and hopefully get them to cover this up. Hopes ain't high tough...
Any ideas how to fix this? Any professional painters around here that could tell me what to do? Tank trim covers some of it.
-JP-
Offline koendd
« Reply #41 on: July 20, 2016, 01:39:07 PM »
damn, that's messed up...
no insured shipping?
1972 cb750K2 brat
1976 cb360
1984 GPZ900R
« Reply #42 on: July 20, 2016, 03:36:09 PM »
Make a claim, assuming the package was insured (it would be silly if there was no insurance from the painter), to USPS.  It will take forever but hopefully they should pay.
Offline -JP-
« Reply #43 on: July 20, 2016, 11:18:24 PM »
Package is insured. All bigger yamiya shipments are. Just spoke with UPS. They will retrieve the package tomorrow for inspection. Then I just have to wait and see...
Offline -JP-
« Reply #44 on: July 24, 2016, 07:39:32 AM »
I got the new coils and wire harness. I took the old ones of the bike today. Harness and rectifier were melted quite badly. So I have to find a new rectifier asap.
-JP-
Offline -JP-
« Reply #45 on: August 05, 2016, 08:15:23 AM »
About the damaged tank. UPS won't cover it. They said that the package didn't meet their instructions. The tank was one of the best packed things I have seen, but that wasn't enough. So there is not mutch I can do. Luckily I have a friend who is a very good painter so hopefully I get that fixed.
Every electronic part has arrived and today I was looking forward to get the bike running again. Set everything up (coils, Hondaman ignition, new regulator and rectifier, fusebox and harness.) No spark. It cranks ok. I couldn't solve the problem. Every part is new out of the box, but I quess I have to test them that everything works.
There was one mystery wire in the headlight bucket. Brown/blue. From the right hand switch. Did some search and some say this is turn signal buzzer wire. Some say it's horn. There was one free wire in the bucket that was coming from the harness. Brown. I assume thats going to breaklight. But I didn't have any wire to match that color. I have a diagram. K1-k2. Diagram says that the brown goes to combination switch. I assume it is the off/on/off switch? I was hoping that this would be an relatively easy task...
Cleaned the solenoid:
-JP-
Offline 540nova
« Reply #46 on: August 05, 2016, 08:36:31 AM »
Put an ohm meter across your mystery wires, and start pushing buttons. If you get continuity, you've found the switch.
1974 CB450, 2006 CBR1000RR
Offline -JP-
« Reply #47 on: August 13, 2016, 09:43:59 AM »
I tried to start the bike without Hondaman's ignition and the bike fired right up. So those coils are ok. The problem is that with the ignition connected it won't give spark from the 2-3 cylinder coil. I filed the points and cleaned them but no success. So I will keep the ignition disconnected and ride a bit and try it again. I also have another problem with the headlight. It won't come on. New halogen. I even opened the switch to check if the reason is there. Everything seemed to be ok. Cleaned everything and painted the housings while I'm at it.
I also synced the carbs the best I could. I found out the other day that there is gas in the airbox so there is something wrong with the floats or something related. So there is some things to take care of before the first ride.
Tach cable is leaking oil where it connects to the motor. I changed the seal for it before. I took the old one out too. Any ideas how to stop the leak?
-JP-
Offline -JP-
« Reply #48 on: August 19, 2016, 10:13:32 AM »
I got some painting finished today. Right and left hand switches. I used fluorescent orange for the texts and Testor bright red for the knob. Under the semi gloss black is primer. I used primer also on the knob. If you are doing this you must get a detailing pen for the letters. It is impossible to paint the letters without it. I'm really happy with the result. I hope the paint holds up. Paint is waterbased acrylic paint from local hobby shop.
-JP-
« Last Edit: August 19, 2016, 10:18:29 AM by -JP- »
Offline -JP-
« Reply #49 on: August 29, 2016, 07:42:17 AM »
I had some trouble with the left hand switch:
http://forums.sohc4.net/index.php?topic=160250.0
Horn still doesn't work. I don't know what is wrong with it. It works when I connect it to battery, but not from the switch. I leave it that way for now.
There was also some problems with the headlight wiring. Headlight didn't come on. Now it is solved too. Not exactly like the diagram shows, but all lights work for now. Is the parking light in the headlight meant to be on when the headlight is on H or L? Mine is on in both positions.
I also changed new clutch cable and assembled the sidepanels.
Still waiting the tank from the painter. I really hope that the result is good.
-JP-
