Author Topic: Help diagnosing short  (Read 1172 times)
Offline OneWheelDrive
  • A journey of 1000 miles starts with your first carb overhaul.
« on: April 06, 2016, 06:14:44 PM »
1975 CB550, with the off/on switch on right control, high/low on left, stock wiring except dummy lights and speedo lights replaced with led. When I turn the lights off from the right control, I'm getting a short I can't track down. Why would it be shorting when I'm turning the lights off??
1975 CB550 cafe
1971 CB500 stocker
2008 Ducati Hypermotard 1100S *sold*
1973 CB350F *sold*
1975 CB550K Project "Keeper" *sold*
2010 Ducati Monster S4RS *sold*
1976 CB360T *sold*
1974 CB550K *sold*
1973 CB750K *sold*
1978 CB550K *sold*
2007 Vespa LX150 *sold*
Offline CB650CPastor
Re: Help diagnosing short
« Reply #1 on: April 06, 2016, 08:21:28 PM »
How do you know you're getting a short? Does the fuse blow?
Tim
Current:1980 Honda CB650C Custom, 1969 Toyota Corona Deluxe Sedan
Past: '07 Honda Rebel 250, '80 Yamaha XS1100 Special, '69 Honda CB160, '67 K15 Suzuki Hillbilly, 1971 VW Super Beetle...
« Reply #2 on: April 06, 2016, 09:11:54 PM »
Yes, blowing the lighting fuse
1975 CB550 cafe
1971 CB500 stocker
1973 CB350F *sold*
1976 CB360T *sold*
1974 CB550K *sold*
1973 CB750K *sold*
1978 CB550K *sold*
« Reply #3 on: April 06, 2016, 09:39:51 PM »
   I'd have a look inside the right control first.
« Reply #4 on: April 06, 2016, 09:40:26 PM »
Yep. Check that control. If it's fine when the lights are on but blowing the fuse immediately when you turn them off, I'd be checking that switch. It may be grounding the positive terminal when you switch it off. If the lights actually work without blowing the fuse, that pretty much rules out the wiring (if it is all connected correctly) and points to the switch.
Tim
Offline Frostyboy
  • Retired: Never was an
  • Circa 1951
« Reply #5 on: April 06, 2016, 11:34:03 PM »
I'm curious now. If you turn the ign on with the lights off, does the fuse blow? Or is it only when you slide the switch from on to off?
To save you blowing countless fuses, remember that if you install a reasonably high wattage bulb across the fuse terminals it will save you changing them all the time. Use at least a 21 watt bulb. If the bulb burns brightly it's saying there's a short. That might let you track it down a bit easier. As you work your way through & the bulb goes out you've found the source.
Last year I joined a support group for procrastinators.
We haven't met yet.
[CB550F1]
« Reply #6 on: April 07, 2016, 08:18:22 PM »
Got an update for y'all.  I opened the right hand control and all looked good.  Then I noticed that the rear light and brake light weren't working, so looked into what could be causing that.  Turned out the Lucas rear light wasn't properly finding ground on my freshly repainted rear fender.  I wired a proper harness ground and fixed it.  Not sure why that would be causing a fuse to blow when the lights were off, but the problem seems to be solved!
« Last Edit: April 07, 2016, 08:31:58 PM by OneWheelDrive »
1975 CB550 cafe
1971 CB500 stocker
1973 CB350F *sold*
1976 CB360T *sold*
1974 CB550K *sold*
1973 CB750K *sold*
1978 CB550K *sold*
Offline Frostyboy
  • Circa 1951
« Reply #7 on: April 08, 2016, 01:43:07 AM »
So it's true! Joseph Lucas is the Prince Of Darkness. Good to know you got it sorted.
We haven't met yet.
[CB550F1]
