Author Topic: made a cam adjust tensioner to 400 four  (Read 857 times)
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=uc64e91auaimvk6ofisk8j0451&/topic,60973.0.html
« on: April 07, 2016, 10:19:39 AM »
have made a new type adjuster schrev..it is umbrakko type head..use a o ring teighting..and kobber as teighting against the engneiblock
have used a m8 umbracco bolt as basis..turned the head dovn to 11,5 mm..and cut a groove for a o ring..and turnde the end dovn to 5 mm for free rotating in the engine..use the 8 mm threds in the engine as caunter schrev..then i can adjust the tensioner..and Lock the vhole part..and it are total Sealed for oil from insiad and vater and dust from autside....the lover Lock bolt can be made the same vay..just a bit shorter..
im put messurings on later after test
« Last Edit: April 07, 2016, 10:27:39 AM by strynboen »
i hate all this v-w.... vords
Offline carnivorous chicken
Re: made a cam adjust tensioner to 400 four
« Reply #1 on: April 07, 2016, 11:50:30 AM »
This is cool -- assuming it'd be the same fit for a 350F. How's it working?
Offline strynboen
« Reply #2 on: April 08, 2016, 04:12:19 AM »
normaly the build in spring press the tensioner...but often it not effektive..so use mine schrev..i can press a bit at the end of the shaft..to help the spring and give some more press..and get the chain more kompessed...
BUT...it have to be done carefull...to hard prerssure vill the chain start eat the tensioner.
..so start the engine(. loosen the lover Lock bolt)..turn the umbracco schrev dovn,,..to the rattel are gone...and back it a bit back..so it not press to hard on the chain..turn/lock the kontra bolt on to the engine block(. that vith the copperdisc). and teight the lover Lock bolt at the engine block. (called adj bolt at Photo).its the one vho holds the tensioner shaft locked
on the Photo pos 5 is removed and my adjuster mounted instead....bu schreving it dovn..i kompreess the tensioner..
the one they call" adjuster bolt.".is in real vorld just a Lock bolt...vho fixing the shaft..bu press on its side....
you can do all this bu a schrevdriver manuel done...just stick it dovn ..and press hard bu running engine..but it are hard and hot job..exhosts like to burn you..this adjuster gives more kontroll..and a better job
« Last Edit: April 08, 2016, 04:20:56 AM by strynboen »
