Author Topic: Starter solenoid wiring CB750K  (Read 3029 times)
Offline RandyBMC
« on: April 09, 2016, 08:24:51 PM »
I have a question on the starter solenoid.  From the pic, do I have it right?  I wired it based on what I could figure out from the manual.
Battery hot and wire harness plug to the forward terminal on the solenoid. (Green/red solenoid wire)
Starter cable to the rear side of the terminal.  (Yellow/red solenoid wire)
It is a 1978 CB750K.
Thanks!
Offline RandyBMC
Re: Starter solenoid wiring CB750K
« Reply #1 on: April 10, 2016, 07:52:25 AM »
Thanks, I got it figured out using the non-colored wiring diagram from the manual.  I was using the one you linked, and it didn't quite make sense to me, at the solenoid.  When I dug out the black and white factory schematic, I figured it right out (I was looking for that diagram in electrical, when it is at the front of the manual).
Appreciate the help!
Randy
