Author Topic: CB550 Rear Wheel Bearing Retainer Removal  (Read 7005 times)
Offline Keith61
« on: April 10, 2016, 09:45:41 AM »
Hello Folks
I need to remove the bearings in the rear wheel of my 1975 CB550 F1 but I am struggling to undo the bearing retainer.
I have read that these may be "staked" but I cannot see any punch marks through the four holes in the retainer . Also that these may be a right or left hand thread depending on year.
Does anyone have any tips that may help please ?? I have made a Heath Robinson tool that should work , soaked the retainer in releasing oil and tried gentle heating of the hub but no joy.
Thanks .......Keith
Offline CycleRanger
  • No comment about being an
Re: CB550 Rear Wheel Bearing Retainer Removal
« Reply #1 on: April 10, 2016, 10:21:56 AM »
Do you have the shop manual yet?
http://honda4fun.com/materiale-documentazione-tecnica/shop-manual
Yeah, it may be reverse threaded. I'm sure some 500 owner will chime in shortly.
Offline Bodi
« Reply #2 on: April 10, 2016, 10:41:32 AM »
The staking is not in the pin wrench holes. There should be punch mark dimples right in the thread gap, you just drill these down about 3/16" with roughly a 3/16" drill bit. On re-assembly, restake the retainer in two new places with a centre punch. You don't need to go mental with the staking. I've also drilled and tapped a #8 screw through the threads and loctited in a SS Allen set screw. Bearing widths are close tolerance but the retainer may not tighten with the stakes matching up again.
Offline Puffin
« Reply #3 on: April 11, 2016, 09:10:34 PM »
I'm pretty sure they are reverse threaded...
I used a decent sized flat headed punch and a hammer.  Put the punch in one of the four holes at an angle and a few sharp blows in the direction you want to move it and it should start to give
Honda CB500 four
Honda CB350 four (under construction)
1972 Cb500 Rebuild Project - http://forums.sohc4.net/index.php/topic,145835.0.html
Offline sinister902
    • Anger Street Kustoms
« Reply #4 on: April 12, 2016, 06:08:30 AM »
IF any of them are regular right hand thread it could be 77-78, but 500 and early (74-76) 550 wheels I've done were reverse threaded. To get it out take a good piece of flat bar and drill two holes in it the distance from one hole to another in the bearing retainer, then thread a nut and bolt through both holes and use the bolts into the bearing retainer as a wrench.
Offline wowbagger
  • Not much of an
« Reply #5 on: April 12, 2016, 08:20:50 AM »
If you want to save the retainer, I'd recommend buying the correct tool for the job: http://www.davidsilverspares.com/CB550F1-SUPER-SPORT-1976/part_237043/
a hammer and punch will damage the holes and reduce the number of times you will be able to remove and reinstall the retainer.
Offline riffman12
« Reply #6 on: April 12, 2016, 08:54:44 AM »
or the cheap one:
http://4into1.com/motion-pro-rear-wheel-bearing-retainer-tool-honda-cb350-cl350-cb400f-cb750f-cb900f-cbx/
Offline wowbagger
  • Not much of an
« Reply #7 on: April 12, 2016, 08:56:23 AM »
Does that one fit the 500/550s? It doesn't say that it does
Offline riffman12
« Reply #8 on: April 12, 2016, 10:49:17 AM »
ah good point. Different size hole spacing huh
Offline greenjeans
  • 1972 CB750K2
« Reply #9 on: April 12, 2016, 11:05:33 AM »
heat and PB blaster are your friend.
Offline Wingnut74
« Reply #10 on: April 12, 2016, 11:07:44 AM »
I just made a perfectly good tool for that - used flat steel strip 1/8' thick 1" wide that was laying around and drilled two holes just small enough hold (interference fit) two 3/16ths drill bits to stick out 1/8".  That was for a CB750K4 so just check what size bits you would need. Took 5-10 minutes to make - worked great.
74 CB360 - Winter 2014/2015 Project
74 CB750 - Winter 2015/2016 Project
70 Something TBD - Winter 2016/2017 Project
Offline sinister902
« Reply #11 on: April 12, 2016, 11:37:48 AM »
it does not.
Offline heyitsrama
« Reply #12 on: April 12, 2016, 02:07:54 PM »
i built my own,  (im not a rich guy like bagger  ::)  ;D ) the spacing from the center of each punch is ~39mm / ~1.56in... mine was reverse threaded....
dont mind my crap welding though, the weld held.
The only mistake i made was not to remove the punch marks out with a drill, so i ended up ruining some of the smaller threads, this was resolved by using a matching pitch tap, and rolling it on the bearing till it took out the messed up sections..... :'(
« Last Edit: April 12, 2016, 02:16:57 PM by heyitsrama »
_____________________________________________________________________________
72' cb500
I can't believe it's not butter.
Offline Keith61
« Reply #13 on: April 12, 2016, 02:50:52 PM »
Thanks for the advice so far. Bit busy at the moment so won't be able to get in the garage till next week.
Think I will have a crack at making a tool as described as what I made was a quick effort involving two bolts and a length of 4 by 2 wood. Just call me tight !!. Will update on how it goes.
One question . What is PB blaster ??
Ta .......Keith
Offline wowbagger
  • Not much of an
« Reply #14 on: April 12, 2016, 02:59:56 PM »
I am also poor. My homemade tool looks very similar to yours except that I welded an old socket to it for easier use.
Offline todd.s.holloway
    • 1975 Honda CB750F
« Reply #15 on: June 13, 2020, 11:22:36 PM »
Does anyone know if the retainer nuts on the 550s are the same size as the 750s on the early 70s models
Sent from my SM-G950F using Tapatalk
« Reply #16 on: June 13, 2020, 11:35:55 PM »
Nope
