Author Topic: swing arm zerk grease fitting  (Read 1308 times)
Offline Chris Liston
« on: November 14, 2006, 11:43:15 AM »
Does anyone know where to get a zerk fitting like what Dr. Tom has on his 550 racer.  Would make life pretty easy for greasing swingarm..
1976 CB550F Cafe in progress
Offline puppytrax
Re: swing arm zerk grease fitting
« Reply #1 on: November 14, 2006, 12:00:16 PM »
That looks like the OEM Honda Zerk fitting fitted to the early CB500/550...but any Ace Hardware store has the screw-in lock-on 1/16NPT fittings to replace it with (requires tapping)...
If you have the later 550 swingarm with the single underneath Zerk fitting, you have a slight problem...   ;D
...stock 1972 CB500 '500 Four' undergoing re-assembly...
...Stock 1972 CL450 'Scrambler' also being re-assembled...
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
« Reply #2 on: November 14, 2006, 12:07:23 PM »
My 500 has one of them (we call them grease nipples over here  ;D - serious)
I thought that they all had 'em!
SOHC4 Member #2393
2015 Tiger 800 XRT
1971 CB500K0 (US Model)
« Reply #3 on: November 14, 2006, 12:18:29 PM »
Yeah, my 76 550 has the single zerk underneath the swingarm.  Its a pain in the but to get too which is why I haven't but NEED to grease.
Offline puppytrax
« Reply #4 on: November 14, 2006, 12:34:42 PM »
Honda still shows them as -
BOLT, RR. SWINGARM
90121-300-000    $23.52
You'll still have to tap them however...or use the press-in no-lock Honda grease nipples...   ;D
