Author Topic: CB550 K0 "Too Long:Didn't Read" Cafe Project Finished  (Read 9908 times)
Offline OneWheelDrive
  • A journey of 1000 miles starts with your first carb overhaul.
Re: CB550 K0 "Too Long:Didn't Read" Cafe Project Finished
« Reply #25 on: May 04, 2016, 04:53:43 PM »
Throaty!
I saw that you used to have a Duc Hypermotard 1100.  I rode one of those ONCE.  Straight up hooligan bike. I had trouble keeping the front end down in every gear.  I could not imagine that amount of power being usable as a supermoto, but definitely as a hooligan bike.
Thank!  Yeah, the Hyper was an absolute hooligan.  It was a fantastic little canyon carver that taught me a lot about bike control, braking, and smoothly using throttle as you could get in trouble very quickly if you weren't focused.  A 75 mile range and the supermoto riding position made it impractical for longer trips though.
« Last Edit: May 04, 2016, 05:07:59 PM by OneWheelDrive »
1975 CB550 cafe
1971 CB500 stocker
2008 Ducati Hypermotard 1100S *sold*
1973 CB350F *sold*
1975 CB550K Project "Keeper" *sold*
2010 Ducati Monster S4RS *sold*
1976 CB360T *sold*
1974 CB550K *sold*
1973 CB750K *sold*
1978 CB550K *sold*
2007 Vespa LX150 *sold*
Offline CBGhia
Re: CB550 K0 "Too Long:Didn't Read" Cafe Project Complete
« Reply #26 on: May 05, 2016, 11:03:30 AM »
Final touches included stainless brake lines from HEL and a properly bled system.  Front brake can now perform as well as the motor!
Dude, I have an easy fix for the unsightly surface rust on the fork tubes.
Go to the auto-parts store and get a roll of the chrome tape they use for the bottom of pickup trucks (runs about 6 bucks).
Slide the headlight ears all the way to the bottom, wrap the top part of each tube.
Then slide them to the top.  Wrap the bottom of that area and then slide the headlight ears to the middle to cover the seam.
Presto!  Much cheaper than $250 for new fork tubes.
« Reply #27 on: May 05, 2016, 04:09:07 PM »
Chrome tape?! Sacrilege.  If you are not going to replace them, I would remove the rust as best as you can (with sanding and/or foil) and paint with Rustoleum.
« Reply #28 on: May 05, 2016, 04:39:16 PM »
Haha, no foil tape, don't worry.  Since that photo was taken I have already removed the rust with 00 steel wool and lightly coated with marvel mystery oil.  I'm planning on replacing the front end eventually with modern forks, so no reason to spend too much time on the aesthetics.
1975 CB550 cafe
1971 CB500 stocker
1973 CB350F *sold*
1976 CB360T *sold*
1974 CB550K *sold*
1973 CB750K *sold*
1978 CB550K *sold*
Offline CBGhia
« Reply #29 on: May 05, 2016, 05:57:02 PM »
If you paint them, they will get scratched all to sh!t when you slide them in.  I cleaned the #$%* out of mine with steel wool and used CLR.  it doesn't really rust, but it it discolored.  the chrome tape looks just fine.   You can't tell it's there.
« Reply #30 on: May 05, 2016, 09:51:52 PM »
Sure.   ;)
Offline CBGhia
« Reply #31 on: May 06, 2016, 05:43:53 AM »
Sure.   ;)
LOL I suppose there are things I should not share.
