Author Topic: Anyone ever try one of these cheap-o Reg/Rectifiers from eBay?  (Read 698 times)
Offline alacrity
  • Ride, Optimize, Repeat
It's WAYYYYY cheaper than the Rick's...  but is it a case of you get what you pay for or is it a case of somebody in Oregon is overcharging?
Because if this thing WORKS for $21, plug and play, reliably...  I see no reason anyone should ever mess with an old VR again.
http://www.ebay.com/itm/290644872204?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
I recently restored and sold a 77 cb750f, and am nearly finished with a (former basket case) cb750k5.  This is a place to share, learn and enjoy.  I am grateful to and for 99+% of this site's membership.
Offline chewbacca5000
  • I polish covers!
Re: Anyone ever try one of these cheap-o Reg/Rectifiers from eBay?
« Reply #1 on: April 16, 2016, 01:25:34 PM »
I don't see why it would not work.  I ordered a generic one and this sucker is huge!  Has a massive heat sink which is good for operation, but kinda big.
Offline alacrity
« Reply #2 on: April 16, 2016, 01:33:36 PM »
you ordered THIS generic one or a different generic one?
Offline Mantree
« Reply #3 on: April 16, 2016, 03:27:30 PM »
I ordered one like it and I'll let you know how it works
Edit
Mine just showed up. It's about 2.5 times the size of the old rectifire and almost all heatsink.  No sort of instruction and the seller was less than helpful about if it grounded through the case so I will be running a ground from the loom to the case just to be sure
http://m.ebay.com/itm/331675907088?_mwBanner=1
Sent from my ME302KL using Tapatalk
« Last Edit: April 16, 2016, 04:34:21 PM by Mantree »
Offline Mantree
« Reply #4 on: April 16, 2016, 04:38:17 PM »
I also ordered some 8 pin waterproof conections so that I can rewire the plugs to 1 conection for easyer work and less mess
uxcell® Cable Connector Plug in 8 Pins Waterproof Electrical Sets Car HID 5Pcs https://www.amazon.com/dp/B00NQB9XJ4/ref=cm_sw_r_other_awd_kXSexbRF6HPPV
You will need a oben berral crimper to crimp the pins
Sent from my SM-G900V using Tapatalk
« Reply #5 on: April 16, 2016, 05:33:28 PM »
Perhaps these are identical to some that are already being sold for much more?! Free shipping and $21. Why not?! Not much to lose.
Offline Mantree
« Reply #6 on: April 16, 2016, 05:37:06 PM »
That's how I felt mine was 30 shipped
« Reply #7 on: April 16, 2016, 05:40:30 PM »
I've got Rick's on my bike and it works fine, but any rec/reg off a modern bike will probably work, when the rec/reg on my Suzuki GS1000 failed, the guy at the local motorcycle wrecker just pulled one off a late model Honda and told me how to wire it in, and it worked fine. Find a good used one off a brand name bike that looks like it'll fit, and just wire it in. Cheers, Terry. ;D
« Reply #8 on: April 16, 2016, 07:30:05 PM »
 I bought one that looks similar for the 12 volt 360 stator on my CL100. So far so good.
Offline Mantree
« Reply #9 on: April 19, 2016, 08:44:17 PM »
I hooked mine up today for a test all lights came on nice and bright and stayed without the flicker they had with the old unit.  I used a water tight conection to rewire the plug
It is a 8 pin plug with the 2 for the regulator in there as well so one less thing to unplug if I need to weld just u plug the wires from the coil and the regulator rectifire plug and disconnect the battery all that's left is wire and light bulbs
