Author Topic: 1976 CB400f Without Kick Start?  (Read 758 times)
Offline jamesd
« on: April 18, 2016, 08:37:55 PM »
Hey there, Just bought a 400/4 and Im curious to know if some of these bikes came without a kick start? Mine doesn't have one, and I cant find a shaft. Only what looks to be a hole where it may have been and a plug that sits pretty flush. I find it hard to believe someone would delete it but I thought Id check. Thanks!
Online jonda500
Re: 1976 CB400f Without Kick Start?
« Reply #1 on: April 19, 2016, 03:00:11 AM »
Someone deleted it - the spring probably broke!
John
A starter clutch thread:
Offline jamesd
« Reply #2 on: April 19, 2016, 07:55:41 PM »
So would there be a shaft in behind this plug? I figured it would stick out a bit. Unless someone cracked open the case to take out the whole shaft.
Online jonda500
« Reply #3 on: April 19, 2016, 09:08:31 PM »
I think someone must have taken the clutch cover off and removed it all (shaft, cog and spring).
John
Offline Kevin
« Reply #4 on: April 20, 2016, 03:34:36 PM »
The shaft and spring will come out very easy once the clutch cover is removed.
It was a common mod to remove the kick start assy to either save weight or as a less expensive option than repairing a broken kick start return spring or the knuckle for the kick start arm.
A couple of 400F's and a
'98 Suzuki Intruder VS1400 ~ for long rides
Offline Bodi
« Reply #5 on: April 20, 2016, 07:21:07 PM »
Less expensive then, and just about your only option now. Both parts are NLA, unless ebay comes up with them you're out of luck. I have searched through crates of lever at several bike wreckers and haven't found one, or any other that will work.
