Author Topic: Counter Shaft ( Drive ) Sprocket ?  (Read 888 times)
Offline rddcw
« on: April 19, 2016, 05:20:27 PM »
I noticed when I removed my Stock Chain from my 75' CB 750 K5 that the front stock 17-T (  sprocket is stamped 750 ) seemed to have a little side to side play ? Is this common or is the sprocket mounted on the splined shaft backwards ? Both sprockets F/R appear to be in good shape. Maybe the front sprocket doesn't have as much center shoulder ( raised portion ) in the rear ? If that's the case, would reversing the sprocket correct the play or does a thin spacer need to be behind the sprocket ?
« Last Edit: April 19, 2016, 09:30:36 PM by rddcw »
Re: Counter Shaft ( Drive ) Sprocket ?
« Reply #1 on: April 19, 2016, 06:25:42 PM »
You're good. Normal.
FYI the stock front sprocket for your bike is 18T. That 17T will give you better responsiveness/acceleration.
Offline rddcw
« Reply #2 on: April 19, 2016, 09:24:49 PM »
That's good to know. I couldn't find anything in the shop manual that indicated which way to the sprocket went. I should of looked at the sprocket closer before I installed it to see if the other side was raised more and if that would make the sprocket mounting tighter. The sprocket is definitely 17-T but wonder why it's stamped 750 ?  I just thought it was the stock sprocket.
« Last Edit: April 19, 2016, 09:30:08 PM by rddcw »
« Reply #3 on: April 19, 2016, 10:21:42 PM »
It may be stock from as earlier year, they made 16 T as well..
« Reply #4 on: April 19, 2016, 10:23:54 PM »
+1 to Frank.
It should have/probably has equal shoulders on each side.
