Author Topic: 1975 Honda CB750F Main Bearing Cap Question  (Read 876 times)
Offline RodSOHC750
  • Restoring Vintage Honda Motorcycles
« on: April 21, 2016, 08:28:12 PM »
While reassembling the crankcase halves, I applied a super thin layer of Honda Bond on the top case main bearing housing faces. I did so to prevent oil migration out the main bearing bolts.  It also appeared as if Honda did the same thing based on some sealant present on the flange faces. I then torqued the bearings bolts to specs.
Any thoughts or concerns?
1979 Honda CB750L Limited Edition
1975 Honda CB750F Super Sport
1972 Honda CL450
1970 Honda CT70
Re: 1975 Honda CB750F Main Bearing Cap Question
« Reply #1 on: April 22, 2016, 03:54:38 AM »
As it should be.  :D
