Author Topic: Need longer swingarm bolt and engine mount bolt for rearset brackets. Any ideas?  (Read 942 times)
Offline palo86
I have a 75 CB550F and am trying to make the rearset brackets I purchased from Cognito Moto work.  The main problem I'm running into is that the swingarm/engine mount bolts are too short to mount the brackets.
Does anyone know where I can source longer bolts?
Thanks!
Chris
« Last Edit: April 22, 2016, 11:07:06 AM by palo86 »
Offline flyintiger
McMaster Carr probably has what you need. http://www.mcmaster.com/#standard-cap-screws/=123hilm
Offline calj737
  • I refuse...
The engine mount bolt (if it's the lower) is 12mm and you won't find a "bolt" that long. Some use threaded rod, cut to length. Others buy solid rod, a tap, and make their own. But as far as I know, I've never seen "longer" bolts made or available anywhere.
The swing arm bolt is even more difficult to locate, so making a replacement is needed, except if yours is grooved for grease, that's more complicated. Can you post a picture of which rear set brackets you bought, as Cognito sells a few different versions.
Offline scunny
  • don't call me expert
don't know if they are what you are after, the 650 bolts are longer, they are used to mount the footpeg mounts.
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline palo86
These are the brackets.
Offline palo86
Thanks for the replies guys.  I'll look mcmaster's and the 650 bolts as well.
