Author Topic: CB500 — hanging idle? [solved]  (Read 16701 times)
Offline Deltarider
Re: CB500 — hanging idle?
« Reply #25 on: May 03, 2016, 07:33:31 AM »
The pilots are #40, the mains #100. I am not sure how to read where the needles are clipped, but I did not change the setting.
Good. Your symptoms do not seem needle related. BTW, there seems to be a difference in needle position in combination with the setting of the airscrew between US and Europe. (US has 4th notch and airscrews 2 turns out, in Europe it's 3rd (middle) notch and 1 turn out +/- 1/8. FWIW. I'm sure you are aware that if you change the setting of the airscrews, the engine will need some time to react.
If I force the throttle forward, I can sometimes bring it back down to a steady idle.
Reading this thread over a question rose. Could it be that your model (like my CB500) is equipped with a throttle grip adjuster (under the switch assy, righthand side handlebar) and that it interferes with proper cable operation? And the cables themselves, do they have enough play?
« Last Edit: May 03, 2016, 07:36:17 AM by Deltarider »
CB500K2-ED Excel black
Offline sammermpc
« Reply #26 on: May 03, 2016, 08:10:17 AM »
Tell me more about this — I have a hunch that some of my problems are related to some ignorance in basic testing procedures (not getting up to temp, etc.)
It is indeed so-equipped. The cables and routing appear fine. To lay that issue to rest, I actuated the throttle assembly by hand, with the throttle cables disconnected entirely (with the help of a lever), and was able to repeat the same symptoms.
I think the bike may simply be running lean. I'm new at tuning, entirely, so I may need to read up a fair amount on the right next steps to take. Is there anything else to keep an eye to besides the airscrews? I've checked the float levels (via clear tube), and they appear fine.
1972 CB500, 1979 CB750F SS (dohc), 1982 Yamaha Maxim XS400
JWExperience
« Reply #27 on: May 03, 2016, 08:25:29 AM »
How easy is it for you to put #42 pilots in your carbs? It's real simple in my 750, 10 minute job. Might be an easy way to richen up the idle circuit and see if you have a change. Sounds like it's hanging because it's lean.
Offline Deltarider
« Reply #28 on: May 03, 2016, 08:31:08 AM »
For adjusting the carbs engine needs to be warmed up. Idle should be around 1100 rpm. It's normal at cold start to give some more throttle to avoid the engine dies. That's why many of us turn the Idle Adjustment Screw somewhat and after the engine has warmed up (and as a consequence idles too high, mine does 3k then) to bring it down again. This is mostly after a km or so.
Wrong practice with these CB500/550s is to turn the four airscrews so far out (leaning) for a highest rpm at idle. No doubt the engine will purr like a kitten, but for these bikes it isn't the right thing to do. These carbs lack acceleration jets and therefore depend on a relative rich idle to have good pick up and driveability whilst accelerating. I find it hard to believe one of the slides does not return well as you mentioned. That would show on the vacuum gauge.
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #29 on: May 03, 2016, 11:15:18 AM »
I found the timing was causing some of my idle trouble.  Even with cleaned and vacuum sync'd carbs with a slightly rich mix.
Offline Deltarider
« Reply #30 on: May 03, 2016, 12:26:26 PM »
It is mostly ignition related. A spark advancer that doesn't work properly, wrongly mounted and/or aligned ignition plates... all this has to be checked and I hope he did.
Offline sammermpc
« Reply #31 on: May 03, 2016, 01:09:07 PM »
Yeah, taking a look at them off the bike, and they come down pretty well. It is not difficult to vacuum balance the carbs, either. Well, not that difficult.
Sounds like I should definitely do this as well. I'll tackle that once I've gone through the testing out the different airscrew positions.
I don't think it'd be that difficult, especially as I'm becoming a pro at pulling these things off (bit cramped to get into the float bowls otherwise). I'll want to wait on that until I rule out everything else.
Thanks for all the help. Hopefully I'll get back to the garage later this week, and will have some updates on the progress.
Offline sammermpc
« Reply #32 on: May 05, 2016, 04:49:56 AM »
Ok, took another look through things, and feeling as puzzled as before. I did a number of tests w/ the idle mixture screws at different positions. First, wow — I didn't appreciate what a noticeable effect these could have.
I also took a look at the plugs after they'd been idle for a few minutes at each screw position.
1 turn out
Idles smooth for awhile, then on throttle blip pulls way up. Runs away sometimes.
Plugs
1 white (very clean)
2 black (sooty)
3 dusky grey
4 white (very clean)
1.25 out
Immediately revs high on start. Adjusted idle back down. Idles steady. Revving returns to idle, but slowly. Does come back to idle, but hunts. Not easy for it. Still appears to return well when hot.
1 Not as lean as 4. Some duskiness but clean
2 black (sooty)
3 dusky brown. Looks good.
4 Very clean & white
1.5 out.
Starts up nicely to idle. Engine is warm at this point tho. No need to adjust idle.  Revs strongly...returns maybe a bit more slowly. Backfire at higher rpm. Hangs around 1.5k before drifting down. After warming up more definitely hovers more.
1 leanish
3 kinda brown
4 extremely clean
1.75 out
Starts nicely; fast idle. Returns on rev but noticeably slower and starts sticking at 1.7k...hunts more, for sure. Then suddenly dropped to regular idle. Revving 5k hovers around 2k.
2 out. Sticks that much higher. Closer to 2.5k+.
Bringing it back down to 1.5 immediately sets idle to lower level....returns but sill hovers and spits. Running it up to 6k for a minute definitely floats and hunts when returning.
After running through this, I felt something like 1 3/8 turns would probably be a good thing to try. This is where it got a bit confusing. I was unable, really, to replicate the observations above. The engine was good and hot now (had a box fan going), and I tried a number of IMS positions, and they all started hanging around 2k.  ??? I tried going all the way down to 7/8, on the off-chance that the temperature was somehow leaning out the mixture, but no change...
This is what the plugs looked like at the end of the evening — from L to R, 1 through 4. You can see 1, 4 are very lean; 2,3 rich. Could that be contributing the symptoms I'm seeing? I'll doublecheck the float levels again...
What else should be on my list?
« Last Edit: May 05, 2016, 04:53:06 AM by sammermpc »
Offline Scott S
« Reply #33 on: May 05, 2016, 05:15:29 AM »
 It almost seems to me that you have a problem other than the carbs. Someone once said "99% of carb problems are electrical".
 Have you adjusted the valves?
 Is the timing set correctly?
 Is your advance mechanism working properly and not sticking? Does it snap back into place when you move it by hand?
 Are you SURE you don't have an air or vacuum leak somewhere.
 Are you SURE the float heights are correct?
 The fact that 2/3 are running so rich points to a spark or timing issue. The hanging idle and backfiring points to a vacuum leak and/or timing issue.
 My suggestion is to baseline the ENGINE by doing the full 3K mile tune up before you make another change on the carbs.
 You said the carbs are off. The only carb change I would suggest is to "center" the main idle screw. The one big one that controls all four carbs. If it was backed out too far during the cleaning/rebuild, you'll never be able to lower the slides enough to get the idle down. You should have threads on both sides of it so that you can raise and lower the slides. This will require bench syncing the carbs again.
 Check the float height. Check your throttle cables and make sure they're not sticking and are moving smoothly.
 After tuning the ENGINE, then vacuum sync the carbs.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
« Reply #34 on: May 05, 2016, 05:36:14 AM »
Are you still still using the original cables? Over time some of the strands break and the cable get these sharp "hairs" on the surface. They can cause friction and cause the cable to hang up inside the sheath. Just a thought.
Offline OneWheelDrive
  • A journey of 1000 miles starts with your first carb overhaul.
« Reply #35 on: May 05, 2016, 09:02:57 AM »
I would put my money on condenser or points combined with an air leak.  It is definitely not your idle screws.
1975 CB550 cafe
1971 CB500 stocker
2008 Ducati Hypermotard 1100S *sold*
1973 CB350F *sold*
1975 CB550K Project "Keeper" *sold*
2010 Ducati Monster S4RS *sold*
1976 CB360T *sold*
1974 CB550K *sold*
1973 CB750K *sold*
1978 CB550K *sold*
2007 Vespa LX150 *sold*
Offline sammermpc
« Reply #36 on: May 05, 2016, 03:30:33 PM »
OK — thanks for the thoughts. It definitely does seem like there's a cross-section of issues at play. I should just go through the 3000 mile tune-up. I was thinking, "I already did that"!, and then realized that I've ridden 3000 miles in the interim!  ;D
I just removed and greased it the other day — this is the mechanism behind the points plate, right? It seems to move smoothly.
The cables move freely (though they are probably worth replacing). I've also tested actuating it without the cables at all, just using my hand (and a lover) — and I get the same performance.
Yes, about two weeks ago. I'll double-check though.
The main idle screw is actually centered! I found a good write-up by Harisluv that helped out on that a lot.
OK. Based on the thoughts here — this is what I've got.
  • Double-triple check that there are no vacuum leaks
  • Verify timing
  • Double-check valve clearences
  • Check condensers & points condition
I'll do some reading up on how to check condensers, as I haven't played with them.
Offline sammermpc
« Reply #37 on: May 09, 2016, 07:22:32 PM »
Updating on my progress — I've done the following:
  • Reverified timing
  • Re-adjusted valves
  • Reset float bowl levels, verified via clear-tube test.
  • Sprayed for vacuum leaks (over and over).
  • Vacuum synched (it synchs up fine)
Symptoms still remain, though I think I'm getting closer. I did notice that my exhaust collars were not as torqued down as they might be, so I nipped those up, which I think may have improved things some.
I took it for a ride, and it performs well across the power band — but it does still have the consistent idle hover. If I overclose the throttle, I can force it down, but it will then bob up. If I adjust the idle low enough, it dies. It appears to worsen as the engine heats up (which I understand can mean a rich condition?) On the other hand, the hover is basically caused by lean, right?
Anyhow, the plugs, actually, did not look that terrible, though definitely #3 (L-R) is pretty rich. Far from an expert at reading these things.
I noticed when running the bike with the petcock off, the idle returned seemed improved. This makes me think that I could try setting my float bowl levels lower (even though I've already set them at 22mm).
Reading over Scott S's thread (http://forums.sohc4.net/index.php/topic,75136.75.html) has been really useful, and leads me to believe that despite my care, I could very easily just have a bit too much gas in the bowls. One thing I've learned in this process, is that the bike is far more sensitive to small adjustments then I would have ever believed. Doing the clear-tube test is a pain (float bowl gaskets, ugh), so I've been a bit lazy in dialing them in. I'll do that.
On my list:
  • Set floats to 23mm (instead of 22mm).
  • Replace points plate (on order w/ David Silver replacement)
  • Trim advancer springs (they do seem a bit soft).
« Last Edit: May 10, 2016, 04:58:26 AM by sammermpc »
Offline Scott S
« Reply #38 on: May 10, 2016, 03:18:00 AM »
 What I found on that old 500 that TRULY fixed it was genuine Keihin pilot jets. That's why I asked what brass you used.
 Looking at the plugs, it's apparent that the 2/3 plugs are running differently. But the 1/4 don't seem too lean.
 I still say you have something wonky with the ignition, because of the way the plugs look.
'71 CB500 K0
'81 Yamaha XS650
« Reply #39 on: May 10, 2016, 09:54:26 AM »
I'm waiting for the result of a points plate/condenser replacement.  Carbs and fuel delivery wouldn't be causing rich/incomplete combustion in only two cylinders.  I'm thinking that below the advance RPM, you're running on only 2 cylinders because of inconsistent spark, then when the timing advances and you get more frequent spark, you blast on all 4 and it hangs (where it's supposed to be running).  Then, when the RPMs drop back down, you lose the two middle cylinders again and it runs poorly or dies.
1975 CB550 cafe
1971 CB500 stocker
1973 CB350F *sold*
1976 CB360T *sold*
1974 CB550K *sold*
1973 CB750K *sold*
1978 CB550K *sold*
Offline sammermpc
« Reply #40 on: May 10, 2016, 07:23:09 PM »
Good thoughts. I'll pull the brass and post photos of the pilots jets when I take a look at the floats — and the points plate is in the mail (I hope). I'll post an update on the results. It'd certainly be nice if it's electrical, as that means my carb job was nice and clean!
Offline sammermpc
« Reply #41 on: May 22, 2016, 08:44:42 PM »
Apologies for the lengthy update — tl;dr — I replaced a lot of parts, most of it didn't make a difference, but tightening up the advancer did. Now I think I have a "conventional" carb tuning problem (I hope). Unfortunately, I still haven't wholly resolved the issue, though I've made some progress.
:: begin the blow-by-blow ::
I replaced the points plate with a new aftermarket assembly (I know that Diachi gets a lot of hate—I have some Toyo points on order). It retimed nicely, though the Daichi points do seem a bit cockeyed compared to the TEC ones.
To rule out vacuum leaks (though I never found any), I replaced the carb boots, the o-rings on the manifold between the carbs and the jugs, and the rubber boots on the airbox. I also replaced the float bowl gaskets—which were a royal pain to get back in—with nicely shaped ones from 4-into-1.
While I was at it, I swapped in aftermarket jets — not sure of the brand. They were from 4-into-1s kits. Size #40. The mains are #100.
New ones are at left.
I did this after realizing that despite my initial efforts, carb dips, etc., at least two of the pilot jets were still a bit clogged. (I wish I had made a note of which)  :-[
After all of that, I had high hopes, but the issues continued — hanging idle, slow-to-return idle, etc.
Looking more closely at the advancer, I realized that in some cases the weights were not returning to make contact with the cam. I trimmed down the advancer springs 1/2 turn and reshaped the ends (per HondaMan's suggestion and as discussed on a number of threads). Now it closes with a nice, confident *snap*.
Throwing that back in there, I noticed an immediate difference. Much more snappy return to idle. I took her out for a ride, and though she behaved well, as the engine heated up, the hanging idle issue began to reappear — sticking around 2.5 - 3k.
Before I tweaked the advancer, it was hard to find a pattern. Now, I feel like I'm starting to see one.
When the bike doesn't return to idle, I'd say 3 outt've 5 times, blipping the throttle seems to *break* it out of the hover, and it drops down to idle. The other times, it'll actually just go higher, almost as if the additional throttle is "added" to the RPM. When that happens, no amount of blipping the throttle brings it down — though under load, you can bring it back down. That seems like an indunction leak. But I can't find it. I double-checked.
I started playing with a few things — when it's sticking high, I tried slowly moving the choke to mostly on (that is, closed; richer). The RPMs don't change, but you can hear a slight difference. Then I blipped the throttle, and *boom* it drops down to idle.
To confirm that the idle mixture was overly lean, I took out the airbox, and enriched the mix by taping over the inlet. (I first tried it with my hand). When the mixture is enriched like that, it does seem to reliably return to idle.
ANYHOW — my operating theory, now, is that I have a lean pilot jet. That could be because the aftermark jets are no good (I'm thinking of recleaning my Keihin's and putting them back in), or some other reason? I've checked the float levels many times, but perhaps those are the issue? I pulled the plugs, but they were all sooty from the enrichened tests, that I think I'll have to do it again with new ones.
At any rate, I do feel optimistic having (hopefully) graduated the issue from a confusing head-scratcher (for me at least), to what seems to be a more normal carb tuning problem. So what's next?
  • Try different pilot jets
  • Double-check everything is clean/clear in the carbs
Many thanks for all of the advice. It's been a bit of a slog, but I feel like I'm learning a bit about the dark arts of carburetors, which is fun...would be nice to get everything 100% (or at least, 90%) as riding weather starts rolling in properly...
Offline Scott S
« Reply #42 on: May 23, 2016, 03:54:49 AM »
 1 and 4 plugs STILL look different than 2 and 3. That points to ignition. Have you changed the points and condenser yet? Coils? Trimmed back plug wires and installed new caps?
'71 CB500 K0
'81 Yamaha XS650
Offline Deltarider
« Reply #43 on: May 23, 2016, 06:54:17 AM »
You've already bumped from stock 38->40 aftermarket, so all stock settings are "off".
Stock pilot jet for all CB500s (with exception of the rare K3 that had PDcarbs) is 40.
« Last Edit: May 23, 2016, 06:55:49 AM by Deltarider »
« Reply #44 on: May 23, 2016, 07:02:52 AM »
Please do an idle plug chop, as calj mentioned, but with new plus.  the ones pictured above ate too stained to really get a good picture of what the idle circuit is doing.
Remind us of your current jetting and mixture screw setting every few posts please.
Offline sammermpc
« Reply #45 on: May 23, 2016, 07:38:42 AM »
Yes — my carbs are 0627b (despite my misidentification in an earlier post).
  • #40 pilot (aftermarket — Keihins on order)
  • #100 mains (stock)
  • Stock airbox; relatively recent (1 yr) paper filter.
  • 4-into-1 exhaust
I replaced the points plate — so new points and condensors. I have not done a proper plug chop since to see if I still have the 1-4, 2-3 variance. I'll do so. I think I need to start buying D7EAs in bulk.
My theory right now, is that my real problem was the timing + the advancer — which I fixed. But because I swapped in the aftermarket jets at the same time, I created a new problem. Two steps forward, one step back...
« Reply #46 on: May 23, 2016, 07:46:00 AM »
TEC points and plate...right?  :P  :-\
Offline sammermpc
« Reply #47 on: May 23, 2016, 09:56:48 AM »
Ha. I wish. I've got some TEC points on order to remove that as a possible issue — though I've read the Diachi points are good for a bit until they wear?
« Reply #48 on: May 23, 2016, 09:59:07 AM »
Prudent.
Offline sammermpc
Re: CB500 — hanging idle? [solved]
« Reply #49 on: June 21, 2016, 05:22:15 AM »
Thought I'd update here, just for the other folks who are inevitably going to run into this common set of problems — after everything was said and done, as many others have, replacing the pilot jets with Keihin #40s made the difference. Swapped them in, and boom — hanging idle was gone.
Embarrassingly, I don't think I actually cleaned my OEM #40 pilots well, despite trying many times. I did not realize there was a hole at the end of jet, which was always clogged, and causing it to run lean on the pilot circuit. When I finally got a new set, I realized my mistake.
Of course, in this process, I:
  • Replaced intake, output boots & manifold o-rings
  • Replaced points & points plate
  • Trimmed advancer springs 1/2 turn
  • Set valves & timing
  • Vac sync'd
  • Replaced float hardware w/ sockets (can change jets w/o removing!)
And yeah, I think I probably could've skipped all of that by just replacing the pilots! All the same, so glad to get it running. Took a beautiful ride last weekend.  ;D
Here she is in full-regalia (looking for a windscreen):
« Last Edit: June 21, 2016, 07:43:55 PM by sammermpc »
