Author Topic: Didn't want to see this...  (Read 2513 times)
Offline gdgreen56
« on: May 03, 2016, 04:44:45 PM »
At some point in this bike's previous life it looks like the chain came off violently enough to dig grooves into the engine casing just ahead of the front sprocket. After splitting the cases it looks like the damage extends all the way through the lower case with a couple of cracks.
The question at this point is - Can this be repaired, and if so, what is the best way?
1976 CB750K Cafe Project
2007 VT1100C2 - Sabre
Offline mystic_1
  • 1970 CB750K
Re: Didn't want to see this...
« Reply #1 on: May 03, 2016, 04:59:30 PM »
Yes, it can be welded.
That's the only "real" fix.
Many many people have just slathered the cracks with epoxy, JB Weld, etc to keep the oil in.
mystic_1
- John Augustus Shedd
« Reply #2 on: May 03, 2016, 05:41:06 PM »
Yes, seek someone out that knows how to weld old aluminum, it needs to be heated to purge the oil in it, then tig welded up.. You are lucky, most of the time, that whole section is either missing or bodged up with epoxy or JB weld, in comparison, yours is a much easier fix... ;)
Offline setdog
« Reply #3 on: May 04, 2016, 08:13:24 AM »
From what I've read in these forums this is definitely repairable.  I also think you caught this just in time because you still have all the original aluminum.
Best tip I can think of is to make sure you qualify that your welder has significant experience with aluminum.  And find a really good fine file, swiss pattern, , to make case edges nice and flat and smooth at the repair site
My toolbox consists mainly of hammers.
76 CB 200T. (sold)
75 CB 750 K5. (sold)
74 CB 750 K4. (current rider)
73 CB 750 K3. (build)
https://www.youtube.com/user/setdog100
Offline thep1pe
  • Proud Owner 76 CB550F1
« Reply #4 on: May 04, 2016, 08:34:12 AM »
Here in the UK we have a product called Belzona. It's a bit like bondo for aluminum. I have used it many times to repair aluminium auto engine's and gearboxes. It's fully machinable and vibration and oil proof. I think it is expensive though I have also used it to repair porous metal and cracked casings.
« Last Edit: May 04, 2016, 08:38:31 AM by thep1pe »
« Reply #5 on: May 04, 2016, 09:25:17 AM »
 Check for an engine shop used to repairing drag race engines. Where lots of aluminum and frequent carnage are normal sightings.
 The next question, is it a nice original numbers match bike now? If you're building a custom or if it's already a bitsa bike just find another engine. It's probably cheaper and easier.
« Last Edit: May 04, 2016, 09:27:53 AM by Don R »
Offline gdgreen56
« Reply #6 on: May 04, 2016, 03:58:25 PM »
Thanks to everyone for the information on this. I was concerned that I'd have to go find another engine...
The bike had only 23K miles on it when I bought it and outside of this one issue the rest of the engine internals are in excellent shape. I like Don R's suggestion to find a shop in the area that does repair work on aluminium racing engines.  If anyone knows of a shop in the Dallas area and wouldn't mind suggesting, I'd appreciate it.
Offline gdgreen56
« Reply #7 on: May 06, 2016, 06:20:47 AM »
 In this type of repair are there concerns about warping the case due to the heat from welding or is it localized enough that it shouldn't be a problem?.
Offline gdgreen56
« Reply #8 on: May 06, 2016, 07:10:49 AM »
I've talked to a couple of shops in my area and I'm not confident that they have the experience to do this type to repair.
I'd be really interested to hear from others in the forum who may have a recommendation for a know competent shop to do this. I don't mind shipping the case off to get the work done. I just want to get it done right...
Offline NobleHops
  • Don ya be callin' me no
  • Misfit - Tucson, Arizona
« Reply #9 on: May 06, 2016, 07:52:35 AM »
My ace welder wanted both halves of a set of cases I had him fix, which he bolted together before he made his repairs, to prevent any possibility of twist or warpage.
I have a motorcycle problem.
« Reply #10 on: May 06, 2016, 08:48:11 AM »
 I know Texas is a big place, these guys are in Sherman TX and if they can't help they will know who can.
http://sunsetperformanceengines.com/
Offline Kingmambo
  • Don't believe the hype
« Reply #11 on: May 06, 2016, 12:25:56 PM »
A talented oxy/acet welder can repair this; using a small torch will put way less heat into it, mitigating the concerns of warpage and the boiling of the aluminum causing impurity issues.  That is the route I would go though I would find an old-timer or very experienced welder.  There are many situations where oxy/acet welding is preferable for aluminum but not many welders have much experience with it.
Kevin
2003 CBR1100XX     1973 CB750K     1975 CB550
Offline gdgreen56
« Reply #12 on: May 24, 2016, 04:31:11 PM »
Got the lower case back from the welder today. The repair looks good, so hopefully no leaking once I get it put back together. I'll have to file the parting line area and may need to smooth off a couple of spots inside the case, but otherwise it looks like a workable repair.
I ended up finding a motorcylce restoration shop in Lewisville,TX close to where I live and got a lead on the shop that does all of their cast aluminium repairs.
« Last Edit: May 24, 2016, 04:32:53 PM by gdgreen56 »
« Reply #13 on: May 24, 2016, 08:23:34 PM »
 Do you know how to drawfile ?,, take your time...
