Author Topic: First high performance rebuild  (Read 2193 times)
Offline Achilles_333
« on: May 03, 2016, 09:24:51 pm »
Hello all, I have a '78 cb750  k . At the moment, I am having some engine compression problems . The cylinders need to bored out as I was stupid and let the engine run out of oil. Yea, feel free to harp on me. Anyway, I've always wanted to upgrade my bike to add more power and acceleration and thought that this would be a great opportunity to get into the engine and upgrade it , since i need to go in there anyway. Also, I bought the bike without an odometer , so I am not sure what mile it is at (I've  considered just replacing everything in the engine to set the "mileage" back to 0)This would be my first time ripping an engine apart. I was looking at some 900cc big bore kits from cycle X . One thing in life that I have learned is that for every action there is a reaction.  If I were to get a big bore it , would it require anything else to supplement the added horse power ? Cranks,cams, valves etc etc? Also,  if I got all required parts and assembled, how would I go about tuning? I would assume that the added horse power would change the specs for tuning since stock is much different that high performance.
Thanks
PS: With that said, since this is my first engine rebuild, feel free to tell me I am way in over my head as far as upgrading.
« Last Edit: May 03, 2016, 09:30:48 pm by Achilles_333 »
Re: First high performance rebuild
« Reply #1 on: May 03, 2016, 09:26:37 pm »
Also, if I were to have different tuning specs, where would I find this information to tune properly or at the least ascertain what would be correct specifications?
« Reply #2 on: May 03, 2016, 10:26:17 pm »
I don't know if you necessarily need to go up to a 900+cc overbore.
You can squeeze plenty of performance out of an 836cc Wiseco high-compression piston kit, good port job, cam and up-graded carburetors.  That will leave you room if you need to rebuild again to over-bore to a 915 cc kit.
You will spend plenty just with these mods, along with heavy duty cylinder studs, seals, gaskets, etc.
You can still use the factory service manual for torque specs and tolerances.
« Reply #3 on: May 03, 2016, 10:43:53 pm »
Thanks, I was looking at the 836cc and was deciding between that and the 900cc. I've been told the same about the 836 and will take everyone's advice on it. I was just thinking about the future. As for the cam , what should I look for in shopping? Also, If I were to get new carbs, how would I go about tuning them. I would assume that the factory 1 turn out for the air screw wouldn't apply.
« Reply #4 on: May 04, 2016, 01:33:21 am »
You need to do some reading Achilles, sounds like you are new to all this, there's a lot to learn and there is a ton of awesome information on this site, some brilliant engine builders too. Do tons of research before spending a dime...
« Reply #5 on: May 04, 2016, 01:41:52 am »
Search in this forum is not that good. Search with Google like: SOHC forums + .....
Easier with 836 when you can bore your original cylinder. Less need of better rods too.
The 900-"915" kits with tapered sleeves that does not need case bore according to the spec is not correct. My K6 case needed a lot of grinding to make space with clearance for the 70mm OD sleeves.
836 kit from JE or Wiseco or APE.
The cheap 836 kit has no room for high lifting cams when pistons are overdimensioned OEM style
The head need to be ported, add 33.5 inlet valves at the same time.
Cam DP295 or similar. This has good response from low rpm. I used a RC 295 copy last summer with 836.
Check with forum member MRieck about everything, work included
« Reply #6 on: May 04, 2016, 11:54:14 am »
Mick is right.  Do your homework.  You can get in deep quickly with an engine build.  A good starting point is what you want this motor/bike to do, how you are going to ride it and how many miles you are going to put on it.
You can easily throw a lot of money at a CB750 engine rebuild.
Offline Mitchell
« Reply #7 on: May 04, 2016, 01:50:04 pm »
I'm going to suggest you look up homdaman and get his book on the cb750, it will help you alot.
Offline gschuld
« Reply #8 on: May 04, 2016, 03:18:59 pm »
I'll second that....right Mike! ;D
If you head down the road toward a fresh build with big power AND high quality in mind, it adds up fast(as it SHOULD).  Lots of upgrades are needed once you get up there in displacement/hipo parts.
Most would agree that a nicely done 836 motor is about the best bang for the buck out there, and plenty of fun.
Perhaps starting with an overall budget might be a good starting point.  You could plan on putting together the best motor you can within your budget.  If your dying to spend piles of cash, going for 100hp or so, we will be happy to help you spend it.... ;D.
George
Offline BPellerine
« Reply #9 on: May 04, 2016, 03:21:24 pm »
not just an overbore to 900,915,requires bigger sleeves and boring block.
1978 CB 750K ard and webers
another anfob
« Reply #10 on: May 04, 2016, 04:42:59 pm »
And if you really want to go all out, buy a billet 1000cc block from Mike Rieck.
Offline Bill/BentON Racing
    • BentON Racing
« Reply #11 on: May 05, 2016, 05:33:22 am »
Yep,  I resemble that remark! Work of art they are!.Bill
BentON Racing Website
BentON Racing Facebook
« Reply #12 on: May 05, 2016, 04:12:10 pm »
Those blocks are things of beauty.
« Reply #13 on: May 05, 2016, 05:29:16 pm »
Indeed    ;)
Offline calj737
  • I refuse...
« Reply #14 on: May 06, 2016, 08:42:17 am »
Please don't misinterpret this, but, if this is your first "performance motor build" then undertaking the direction you're contemplating, may not be highly advisable. To achieve quality results requires knowledge, experience, and lots of specialized tools. There's no "book" for following a Hi-Po 750 build recipe. Some of the information is available, but lots of it is esoteric and buried within the deep recesses of the experienced folks. Meaning; its not documented.
Establish a budget. Locate and arrange a qualified engine builder. Accumulate the parts you know you want and will need, then rely upon them to assemble and assure its proper function. Tuning will best be handled on a dyno, backed by good advice from the myriad of folks on the HiPo forum. Whatever you seek, its probably been done (with mistakes, errors and lessons learned) before so you can avail yourself of their wisdom and avoid the pitfalls.
Clearancing parts to 0.000s is not something most people can do in their garage without ample micrometers and dial gauges, and other tools. You can certainly contract a number of reputable places to build you an engine complete, or subcontract aspects out (head to Mike Rieck, crank to APE, trans work to Fast...) and then have a local shop assemble to spec. Theres no shame in relying on professionals to do professional work. You get the enviable task of putting together a wish list of quality parts and features, they take the brunt of responsibility for accuracy.
If you remain steadfast in your desires, then start with a less ambitious project to cut your teeth and limit your cost/damage would be my parting advice.
Either way, I hope to see a top shelf engine in your project soon!!!  :D
Offline Big Jay
    • CBRzone
« Reply #15 on: May 13, 2016, 09:55:02 pm »
Spend some time here;   http://cbrzone.com/sohc.html
