Author Topic: Carb problem, Bike cannot go to idle.HELP~~  (Read 3789 times)
Offline Marco83
    • *My PhoTo AlbUm*
« on: November 16, 2006, 07:35:20 AM »
Hi all,
Recently I got a 2nd hand cb400f carb off from ebay.
The carb look quite nice to me and I bought 4 set of keyster carb rebuild kit from ebay to
rebuild the carb. The carb is fully rebuild( change every part) and clean. But once I install the carb onto my bike, my bike fire up right away(My old carb cannot get my bike start).
But once the bike start, the RPM will run up to 2-3k..After a while the bike just die off.
When I start again but still encounter the same problem, the bike just cannot go to idle mode.
I already try to adjust the idle screw (the main one), but seen no different.
How do i sync to make it right?Btw i got no vaccum meter. I have read the FAQ for Carb but still dun understand how it work...
Really need help on this issue.
Pls advise..
The attach photo was taken after the rebuild.
Thank
Marco
« Last Edit: November 16, 2006, 07:44:19 AM by Marco83 »
Re: Carb problem, Bike cannot go to idle.HELP~~
« Reply #1 on: November 16, 2006, 07:52:18 AM »
You need to do a full service (points,timing,tappets,camchain) then use vacuum gauges on the carbs
Offline Klark Kent
« Reply #2 on: November 16, 2006, 07:54:07 AM »
also check spark plugs caps and wires for old-badness.
-KK
-KK
75 CB550k
95 KLR650
www.blindpilotmovie.com
download the shop manual:
you'll feel better.
listen to your spark plugs:
Offline Marco83
    • *My PhoTo AlbUm*
« Reply #3 on: November 16, 2006, 07:58:36 AM »
last year my bike still running with my old carb..
Offline Marco83
    • *My PhoTo AlbUm*
« Reply #4 on: November 16, 2006, 08:00:06 AM »
-KK
Had check everything..Bike always start with a few kick.
But just cannot enter idle mode..
dave550K
« Reply #5 on: November 16, 2006, 11:43:53 AM »
I had the same problem and it was a dead battery. Just a thought.
Dave
Offline mb3000gt
« Reply #6 on: November 16, 2006, 01:09:52 PM »
did you bench sync them after rebuilding? what are the air screws set at? are you sure the rubber boots are tight?
Offline Marco83
    • *My PhoTo AlbUm*
« Reply #7 on: November 16, 2006, 03:56:26 PM »
Dave
it work fine when i put in another carb..
Offline Marco83
    • *My PhoTo AlbUm*
« Reply #8 on: November 16, 2006, 03:59:17 PM »
nope, never set and how to set the Bench sync??
nope also, how to set the air screws?
rubber boots are tight!''
thank
marco
Offline heffay
« Reply #9 on: November 16, 2006, 04:00:47 PM »
did you add the idle grease?
Offline Hockers Choppers
  • go away winter!!!
« Reply #10 on: November 16, 2006, 04:10:09 PM »
Turn your air screws in all the way and then back them out 1 1/2 turns and see what you have then. If that doesn't work you may have some blocked idle circuit's. take off the carbs again and try blowing carb cleaner thru all of the small passages.
The thing about common sense is that, it's not that common.
1978 CB750F SUPERSPORT 850cc, cam, porting, dyna ign, cr29's lotsa elbow grease and $$'s. Worth ever penny!!  (S0ld)
05 VTX1800F darkside
cb750 k1
Offline Marco83
    • *My PhoTo AlbUm*
« Reply #11 on: November 16, 2006, 04:11:13 PM »
what is idle grease?
really not very good at this.
pls advise..
Thank
  • go away winter!!!
« Reply #12 on: November 16, 2006, 04:12:28 PM »
Come on man! ::)
cb750 k1
Offline Marco83
    • *My PhoTo AlbUm*
« Reply #13 on: November 16, 2006, 04:14:53 PM »
I will try this tonight.  :)
Offline Marco83
    • *My PhoTo AlbUm*
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #15 on: November 16, 2006, 04:44:10 PM »
Marco,
He was pulling your leg. Not fair.
Offline Marco83
    • *My PhoTo AlbUm*
« Reply #16 on: November 16, 2006, 04:50:19 PM »
Marco,
guys pls help!
upperlake04
« Reply #17 on: November 16, 2006, 06:47:47 PM »
Marco -  I don't know if the 400F has a non-adjustable slide in the #2 carb, but remove the caps from the tops of the carbs and look at the linkages. If #2 doesn't have the adjuster screw, use the main idle adjust thumbcrew to lower its slide to just friction fit a drill bit (or something else). Then adjust the other slides with their linkage adjuster screws so all are the same. Bench synch is not as accurate as a vacuum synch but it will get you close.  Good luck!
Offline Klark Kent
« Reply #18 on: November 16, 2006, 06:54:37 PM »
does size of drill bit matter?  i used a 1/16" bit, and youve got what looks like a 1/4"... is there a suggested spec?
-KK
-KK
75 CB550k
95 KLR650
you'll feel better.
upperlake04
« Reply #19 on: November 16, 2006, 07:06:57 PM »
KK - no, it doesn't matter. The idea is to adjust them to the same height - then use the thumbscrew to adjust the idle.
Offline Marco83
    • *My PhoTo AlbUm*
« Reply #20 on: November 16, 2006, 07:12:44 PM »
will that work after adjust?
Can you post the step by step with the pic?i' very noob on bike.
Really a big thank if you can do that!
Marco
« Last Edit: November 16, 2006, 07:30:53 PM by Marco83 »
Offline miles nowhere
  • motorbikeist
    • Miles Hunsberger Tattoos
« Reply #21 on: November 16, 2006, 08:16:35 PM »
you could also have an air leak somewhere between the carbs. If you broke the carbs down completely, they might not have gone back together tight enough.
78 cb 750k8, 78 cb 750F3, 78 cb 750F3, 74 cb 750k4
Offline Marco83
    • *My PhoTo AlbUm*
« Reply #22 on: November 16, 2006, 09:34:57 PM »
What are those i need to look for?i mean where are those place properly will encounter air leak?
Thank
Marco
« Last Edit: November 16, 2006, 09:52:12 PM by Marco83 »
Offline oldbiker
  • I HATE RAIN
« Reply #23 on: November 17, 2006, 02:53:12 AM »
He means check the rubber connecting tubes for good fit..
