It's due time I start this thread. On 10/10/15 I hit a bump, nothing special, a small bump you wouldn't even notice in your car. The rear wheel began a dance, a soft wiggle quickly became a violent weave. I was like a cowboy at a rodeo, trying desperately to hold on but to no avail. I got tossed off the right side, bounced and rolled about six times, hit nothing, got hit by nothing, broke nothing. ALL THE GEAR ALL THE TIME OR DIE! Seriously, I probably should have died.
So not only did I get lucky enough to be on my feet after that but my bike actually got luckier. Laid down pretty smoothly on the right exhaust, bars, and pegs, not much else. It was kind of odd to see flashes of sparks in between somersaults trying to figure out what way was up and when it would all come to a stop. Anyway, I decided to kick it over to see if it would start, and what would you know? First kick.
Longest. Scariest. #$%*test. Ride. Home. Ever.
So upon tear down I find no frame cracks, everything measures straight, lucky again. What I do find is worn out rear shocks, 1/8 inch of play in the swing arm, 40 year old oil in the front forks, steering and wheel bearings just as old. So I plan to rebuild and replace all of that, plus the damaged bits, and do some custom stuff that I've always wanted to do.
the bike as it sits today
the "to do" list
some parts I painted
two inspirational bikes
