Author Topic: Show me your steering dampers!  (Read 30225 times)
Offline nobody
« on: May 10, 2016, 08:08:12 PM »
I'm curious to see how everybody is mounting theirs so I can get some ideas on mine
here's mine
also, this
74 cb750k
Offline Deltarider
Re: Show me your steering dampers!
« Reply #1 on: May 10, 2016, 11:20:27 PM »
I'm more interested to see more of the box in the far left of your first photo, the box in red and black with a yellow stripe.
« Last Edit: May 11, 2016, 07:46:35 AM by Deltarider »
CB500K2-ED Excel black
Offline calj737
  • I refuse...
« Reply #2 on: May 11, 2016, 06:39:32 AM »
Hey Matthew - It would be helpful if you would indicate what bike you are working with, and what front end (stock or modern swap, custom triples, etc) so relevant solutions can be pictured for you.
Online Stev-o
« Reply #3 on: May 11, 2016, 07:15:51 AM »
I'm about to remount the damper on my K3, the PO welded a bracket on the frame and the other end mounts to the fork tube.
Does your lower triple have a hole in it? You may be able to bolt it there.
Can post pics later, need to go to work...
Offline nobody
« Reply #5 on: May 11, 2016, 08:26:18 AM »
Always important info. I have a 74 k4 750 with the stock front end and triples, the lower triple does have that threaded hole so I think I'll mount there. I'm more in the fog when in comes to where on the frame to clamp and connecting the damper to said clamp.
That Targa mount is slick
74 cb750k
Offline calj737
  • I refuse...
« Reply #6 on: May 11, 2016, 08:33:18 AM »
The image of yours shows a clamp designed to accommodate the front frame tube. The adjuster knob should extend beyond your forks to provide access while driving.
Use care when tapping the lower. Its cast iron, brittle, and can be hard to drill. A little thread sealant is a good measure for installation.
Offline nobody
« Reply #7 on: May 11, 2016, 09:13:17 AM »
The hole in the lower is already tapped, I think, so I'm just going to have to find a bolt with the right thread.
Could you elaborate on what you're saying about the adjustor knob?
I forgot to answer you earlier, that box has a points plate assembly in it.
74 cb750k
Offline Deltarider
« Reply #8 on: May 11, 2016, 01:07:35 PM »
Yes, a Daiichi. I'd rather spend my money on a good points plate assembly than a steering damper.
« Reply #9 on: May 11, 2016, 01:15:16 PM »
+1
Ditch the Daiichi, Matthew, and get a OEM TEC or ND points plate.
Offline nobody
« Reply #10 on: May 11, 2016, 01:20:17 PM »
Damn it, I bought that as an extra and you're telling me I wasted $40?
What's wrong with Daiichi?
74 cb750k
Offline nobody
« Reply #12 on: May 11, 2016, 01:30:15 PM »
damn it  >:(
74 cb750k
Offline Deltarider
« Reply #13 on: May 11, 2016, 01:36:44 PM »
Fair is fair, there seems to be enough riders that are content with Daiichi.
You still haven't informed us why you think you need a steering damper.
JWExperience
« Reply #14 on: May 11, 2016, 02:49:31 PM »
I have the same damper as the OP. I put mine on because I got a hairy wobble over bumps at highway speed. Next I'll replace the bushings in my swingarm.
Offline DaveBarbier
« Reply #15 on: May 11, 2016, 03:23:29 PM »
+1
+2
I had issues with Daiichi condensers, and points at separate times. TEC all day!
On my 550. Left frame tube to the threaded hole on the right side of the lower triple. Easy access to the adjuster while riding with my left hand.
Online Stev-o
« Reply #16 on: May 11, 2016, 03:33:45 PM »
Yes, bolt it to your lower Triple like this.
This is my H1 [yours may be different], the bolt size is 8x60mm and I used a nyloc nut. Pretty simple.
Looks like my triple needs paint!
« Reply #17 on: May 11, 2016, 03:56:42 PM »
+1
+2
I see in a lot of the pics here dampers bolted onto the right side of the bike, I prefer the left as in the picture above, you can adjust the damper without taking your hand off the throttle. Unless they changed the hole in the bottom triple clamp, it should be threaded, find a metric bolt that fits and use that, I usually have a small mount welded to the left downtube, I prefer them to be mounted to the frame, not a clamp....
Delta, if you don't know why dampers are used, after being told numerous times already,  its a waste of time explaining it over and over again..
Online Stev-o
« Reply #18 on: May 11, 2016, 04:00:35 PM »
+1
+2
Hey Mick ...  totally unnecessary on a 500 at slow speeds. Trust me!
JWExperience
« Reply #19 on: May 11, 2016, 04:11:04 PM »
Mines on the right side because there was a hole already threaded for it, besides, why would you really need to make adjustments that you couldn't wait until a stop sign/light for. Not like I'm doing track days.
Offline calj737
  • I refuse...
« Reply #20 on: May 11, 2016, 04:13:27 PM »
The knurled end of the damper is the adjuster. It allows you to tune the resistance for street/city riding versus open road way where your speed differs. In the city, lighter steering, open road at faster speed, more resistance to help maintain stability. Thats why the guys are talking about left side or right for tinkering while riding...
« Reply #21 on: May 11, 2016, 04:17:12 PM »
Because you can use a higher setting on highways and lower settings for round town, the higher settings give more stability at speed, high settings can cause a weave at slow speeds, that's why they are adjustable...
JWExperience
« Reply #22 on: May 11, 2016, 04:54:23 PM »
Now you're just being nit picky. My bike is much more stable on the highway and I use the same setting...always. Most sport bikes come with non adjustable dampers anyways.
« Reply #23 on: May 11, 2016, 05:15:25 PM »
Why are they adjustable then..?  Your bike isn't more stable on the highway at all, there's just less turns and no sharp corners to contend with and a generally flatter surface, you are going faster, thats all, I've had a tank slapper that broke my steering stops and nearly broke my thumbs, I was amazed I didn't throw the bike down the road, I've used dampers ever since. Turning up a damper on high speed sections of the road increases stability by slowing down or stopping oscillations in the front suspension and wheels, it sound to me that you've never done anything but stuck a damper on a left it alone..?  I suspect you probably don't know much about adjustable suspension either..?  The damper is actually part of that set up...
JWExperience
« Reply #24 on: May 11, 2016, 06:15:56 PM »
Blah blah blah... I've had tank slippers too. MY bike is more stable. I would know, I rode it before...when I got those oscillations you speak of and now they don't happen. And yes I rode it with different setting to see where I liked it and where it would work for MY riding conditions. Sorry if this offends you. Again, tell me why modern sport bikes coming off the showroom floor today don't have adjustable dampers IF ITS SO VITAL.
Oh and to finish measuring our wieners...I've rebuild my suspension too and understand dampening, rebound etc.
I'm so annoyed when people post topics looking for help and other people give such definitive responses like you did about where the damper has to be mounted. Then you get upset when somebody else suggests an alternative. God forbid somebody does it differently. Isn't that the point of the forum, to share knowledge? Every conversation with you goes this route...
Sorry for the hijack to the OP, your damper will work well for you no matter which side you mount it.
« Last Edit: May 11, 2016, 06:25:31 PM by JWExperience »
