Author Topic: Show me your steering dampers!  (Read 30385 times)
Offline joeyvans
  • Definitely not a
  • God's Country, Earth
Re: Show me your steering dampers!
« Reply #125 on: May 24, 2016, 08:09:56 AM »
Wow... Guess I am late to the party! Woo!
Not a 750, but bolted mine to the right side of the lower triple and used a fork/frame clamp from 'Fast From the Past' on the left side of the frame for adjustment on the fly.
1976 CB550 K2
Non-SOHC4 - 1974 CB450 K7
Non-SOHC4 - 1996 VFR750F
"No matter how much you shake and dance... the last three drops go in your pants."
« Reply #126 on: May 24, 2016, 08:28:12 AM »
So, speaking of mounting options, I've been pondering geometry.
If you use this hole, and mount the damper on the right side of the frame, it seems pretty clear that you'll get a decent "sweep", that is, the distance between the hole and the right side frame downtube will be shortest at full right steering lock, and longest at full left steering lock.
On the other hand, if you use that same hole but mount the damper on the LEFT side of the frame, so that it's crossing diagonally across the front of the frame, do you still get the same amount of "sweep"?
I could math this out, and will when I get the time, but I thought I'd ask to see what you gents knew about it first.
thanks
mystic_1
I'd like to see what you come up with, mystic.
I didnt like the feel of mine mounted on the R lower triple hole.  Seemed like small bar movements didnt engage the damper enough for it to feel effective, so I relocated it all to the left side.
Offline Whaleman
« Reply #127 on: May 25, 2016, 10:26:46 AM »
Just installed the ebay kit linked on the first page. It comes from Yamiya in Japan. Fits and works perfect. I got an email from Yamiya telling me in the future it is cheaper to order directly as opposed to buying through Ebay. Dan
Offline DaveBarbier
« Reply #128 on: May 25, 2016, 05:49:32 PM »
thanks
mystic_1
I agree. I posed this question when I got my steering damper on my build thread. Mine too goes from the lower right triple to the left side frame rail. I've never felt a working steering damper but if I change the setting from strong to weak I only notice a little difference. I think it should be stronger.
I took it as giving you more mechanical advantage making you able to turn through the damper easier rather than not engaging the damper because of a shorter movement. If I remove the damper and have it in my hand even trying to move it a half inch gives strong resistance.
Offline DaveBarbier
« Reply #129 on: May 26, 2016, 12:48:33 PM »
Ok, just because of Mystic and Flybox I moved my damper to the entire left side. I can definitely feel a difference. Helped that I had a fork clamp laying around.
Offline joeyvans
  • Definitely not a
« Reply #130 on: May 26, 2016, 12:52:11 PM »
Nice, Dave! I might have to move mine now too. I will measure my forks, but what size fork clamp are you using and where did you acquire it?
1976 CB550 K2
« Reply #131 on: May 26, 2016, 02:11:50 PM »
+1...like that clamp
Offline DaveBarbier
« Reply #132 on: May 26, 2016, 02:39:29 PM »
I got it a few years ago, the seller on eBay doesn't even exist anymore, haha. The title of the listing was '35mm steering damper bracket'. It was like $25.
And yeah, it's a 35mm clamp for the forks on the 550.
Offline joeyvans
  • Definitely not a
« Reply #133 on: May 26, 2016, 02:43:50 PM »
Thanks for the info! The 'Fast From the Past' clamps are really nice, but they are $36. They have 2 M8 threaded holes, which was nice for my frame mount, but I think I would prefer just 1 threaded hole for the fork side.... just like yours.
1976 CB550 K2
Offline DaveBarbier
« Reply #134 on: May 26, 2016, 02:51:50 PM »
This is a similar clamp to mine:
https://www.ebay.com/itm/201364177916
Mine has a milled section which this doesn't have so we can't be twins, :). Makes it look like an excited robot.
Offline joeyvans
  • Definitely not a
« Reply #135 on: May 26, 2016, 02:54:26 PM »
Haha! Yeah it does. Looks like that other one ships from China.... ugh! Might still go with the FFTP clamp. Thanks again, man!
1976 CB550 K2
« Reply #138 on: May 26, 2016, 02:58:02 PM »
Offline Swoop
« Reply #139 on: May 26, 2016, 04:26:06 PM »
Why not tone things down and start a gun control thread?
Lighten up....he only asked how to mount the damn thing!
Offline Sgt.Pinback
« Reply #140 on: May 27, 2016, 03:36:53 AM »
Old "HONDA - schuh" damper
Doc, I love a motorcycle!
Offline Gman
« Reply #141 on: May 27, 2016, 05:32:44 AM »
http://www.banggood.com/Aluminum-Steering-Damper-Fork-Frame-Mounting-Clamp-Bracket-For-Motorcycle-Bike-p-1042752.html
From Banggood.  I know, right?  Just a joke waiting to happen.  "Why, yes I do!"
However, I ordered one (35 mm) a few weeks ago and just got it.  Looks to be decent - only issue is the bolts that came with are too short for my liking, as they only go a few threads into the body.  Easy fix.  For $10, figured I couldn't go wrong...
G
'76 CB550K
Stock airbox, MotoGPWerks 4-1, HondaMan ignition, Lesters
Offline mystic_1
  • 1970 CB750K
« Reply #142 on: May 27, 2016, 05:59:19 AM »
The main thing I worry about when it comes to cheap aftermarket parts is material quality.  I wonder what alloys are being used, and how high the quality of the raw materials was when they made the parts.
I'd never managed to break a pair of standard pliers just by squeezing them with my hand, until I bought one from Harbor Freight.  It snapped like a dry twig, and I wasn't even in Hulk mode at the time.
After that of course there's issues of fit and finish and the engineering (if any) that actually went into the design.
On the other hand, sometimes a clamp is just a clamp, and i do tend to worry too much about things.   ;D
mystic_1
- John Augustus Shedd
Offline joeyvans
  • Definitely not a
« Reply #143 on: May 27, 2016, 06:34:51 AM »
That review wasn't helpful, mystic?
1976 CB550 K2
« Reply #145 on: May 27, 2016, 08:52:41 AM »
Has anyone used the shorter throw Ohlins dampers on their bikes?
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #146 on: May 28, 2016, 07:54:34 AM »
Now that would be fun!
Offline brewsky
« Reply #147 on: May 28, 2016, 09:07:57 AM »
No difference between gun control and steering damper........just use both hands either case!
Take both hands off the bars at 45mph on decel and see!
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
« Reply #148 on: May 28, 2016, 09:16:40 AM »
 My 836 , with the stretched swingarm......you could let go of the bars at 45 mph, downshift without clutch and get down to about 10 or 15 mph.. no hands no problem...... is that OK ?
« Reply #149 on: May 28, 2016, 10:31:26 AM »
Video or it didn't happen!
