Author Topic: CB750 round tops; bowl drain screw thread?  (Read 1036 times)
Offline Garage_guy_chris
« on: May 11, 2016, 09:27:38 AM »
Hey guys im sitting at work and need to know what the thread size is on CB750 round top bowl drain screws? I imagine its either M5x0.8 or M6x1.0
I want to do the clear tube test and had a thought about how to make some fittings using the drain screw holes to hook the clear tube too
Offline harisuluv
Re: CB750 round tops; bowl drain screw thread?
« Reply #1 on: May 11, 2016, 10:26:52 AM »
i think it's an m6.
Offline dusterdude
« Reply #2 on: May 11, 2016, 11:07:27 AM »
Its a bastard 6mm but i dont recall the pitch at the moment
Sent from my LG-D850 using Tapatalk
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline dusterdude
« Reply #3 on: May 11, 2016, 11:10:10 AM »
I think its 6x.07
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #4 on: May 11, 2016, 11:39:04 AM »
Get a spare drain screw and cut off the big part. Then press it into the end of some 1/8" clear tube.
--Evan
1975 CB750K "Rhonda"
Offline dusterdude
« Reply #5 on: May 11, 2016, 03:52:49 PM »
Check with cal on the hose size,when we checked mine we stuck the hose in the hole,worked out good
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
« Reply #6 on: May 11, 2016, 08:21:48 PM »
When i got home from work i took a look at some loose ones the thread is a metric fine M6x0.75 it is a dead thread pitch from what i can tell i checked on McMasterCarr and nothing, called my local bolt and hardware supply shop and they had nothing chain wide...
I was planning on getting some bolts drilling them out running a nut down to the shank and bingo have some spigot tap things to check fuel level but its a no-go
