Author Topic: Fitting rubber caps onto brake and clutch levers  (Read 1354 times)
Offline intruder
« on: May 11, 2016, 11:51:55 PM »
Can anyone please advise a recommended way to install new rubber caps onto CB750 brake/clutch levers avoiding damage to them. Thanks.
Offline jaytee-nz
Re: Fitting rubber caps onto brake and clutch levers
« Reply #1 on: May 15, 2016, 05:30:43 PM »
Try heating them in hot water first to make them more pliable / flexible and putting some methylated spirits on the ball of the lever as a lube (it will eventually evaporate).
If the caps are new they will handle a stretch over the ball.
Cheers - JT (New Plymouth)
