Author Topic: First serious build ever - CB750 K7 Café  (Read 25138 times)
Offline cb750tr
Re: First serious build ever - CB750 K7 Café
« Reply #100 on: November 23, 2016, 04:52:40 AM »
Alright, progress. The triples are on their way to get powder coated, which motivates (forces) me to make a solution on widening the front. Going to make a new wheel axle. The spacers are extremely easy to make for CBR1000F as it uses two spacers stock (which are about 10mm and 22mm in width) so I'll just make two new ones and add 10mm to these.
It should be somewhat easy to make new brackets for the calipers as well, but that's a later headache. I want to get the thing rolling before I start working on the brakes.
Offline cb750tr
« Reply #101 on: November 25, 2016, 01:47:07 AM »
Easy part done. Awaiting triple to get back from powder coat and I can assemble it.
Offline cb750tr
« Reply #102 on: November 25, 2016, 08:38:20 AM »
So far, so good!
Offline cb750tr
« Reply #103 on: November 25, 2016, 09:24:11 AM »
Updates in real time! Making some spacers for one of the calipers!
Offline cb750tr
« Reply #104 on: November 25, 2016, 10:31:50 AM »
I'll take it!
Offline budman
  • 1914X
    • LeCompte Electric Bass
« Reply #105 on: November 25, 2016, 05:34:56 PM »
Nice!
Bud
1973 CB750K3 Chopper
2021 Indian Scout
Offline cb750tr
« Reply #106 on: November 26, 2016, 01:26:58 PM »
Started on the other side. It's a lot more complicated since the caliper bracket includes another cylinder that engages one of the pistons in the rear, and I'm not going to use that, so I do not have anything to mount it to on the other side. So have to make a custom adapter bracket.
I started with changing the offset 10mm by milling that much off the lower mounting point and making a spacer, which seems to work fine.
That's as far as I got today, took a lot of thinking and setting up to be able to do it right.
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
« Reply #107 on: November 26, 2016, 04:22:25 PM »
looking good  ;D
Offline cb750tr
« Reply #108 on: November 27, 2016, 07:34:43 AM »
Almost there!
Everything's lined up and in place, the only thing I have to do is to mill a flat adapter bracket to mount the other side of the caliper bracket.
Stoked!
Offline cb750tr
« Reply #109 on: December 30, 2016, 08:59:05 AM »
Boom. Front end complete.
Offline cb750tr
« Reply #110 on: December 31, 2016, 07:37:29 AM »
Lost count of how many times I've done this.
« Reply #111 on: December 31, 2016, 08:13:22 AM »
Needle bearing for caliper mount?
Offline cb750tr
« Reply #112 on: December 31, 2016, 08:40:25 AM »
It had three of them stock. I have no idea, never seen it before.
Offline cb750tr
« Reply #113 on: January 04, 2017, 02:41:45 AM »
It's awesome to have a new workshop dedicated for just my projects, just a few minutes away from home. I can go and tinker for just an hour or so, when I want to have some time to myself instead of dedicating my entire afternoon like before.
I really love how the front end and top triple turned out. The bike has another stance, and I absolutely adore these rims on the CB750. So far the project is going to plan.
Got the last milling done of the brake adapter yesterday. So now the front end is completely done, just waiting for the cylinder to arrive from China (I'll take my chances with it).
Also got the carbs cleaned and assembled again. The rust from the tank had clogged quite a bit. Especially the fuel lines and the needle valves (or whatever they're called). Fortunately they weren't damaged, and are once again sealing properly.
I'll go with a bottle for a tank until my new tank arrives... From which I've stopped getting e-mails from the guy making it, so I'm starting to get a bit scared about that. I hope he hasn't decided he doesn't want to do tank and seat anymore. That would be a bummer...
Also removed the intake rubbers from the airbox. One of them is really, really stiff (think plastic). Going to give it a try with soaking in some oil and see if I can mend them, or if I have to try to find another set. Hopefully not.
Offline calj737
  • I refuse...
« Reply #114 on: January 04, 2017, 03:02:38 AM »
A blend of Wintergreen oil and water, boil the intake boots in it, softens them right up.
Offline cb750tr
« Reply #115 on: January 04, 2017, 03:08:33 AM »
Will try this, thanks Cal!
Is it Methyl salicylate you mean by Wintergreen oil, or is it a specific product called Wintergreen oil?
Offline calj737
  • I refuse...
« Reply #116 on: January 04, 2017, 03:17:54 AM »
Here's the standard "process" used by many:
- "Put ~2oz of wintergreen oil into a pan with enough water to cover a set or two of carb boots (maybe 1/2-3/4 gallon depending on pot size).  Put a screen in the bottom so they don't touch the pan, and heat them to near boiling (when those little bubbles start forming on the boots) for about 30 minutes.  When they dry they're like new again.
Make sure ya do it outside unless you want your house smelling like a Wint-O-Green lifesaver for a month."
Yep, same stuff, Professor Chemistry  ;)
Offline cb750tr
« Reply #117 on: January 04, 2017, 05:43:34 AM »
Awesome! Thanks very much. I'll return with the results, but I don't see why this wouldn't work!
Offline cb750tr
« Reply #118 on: January 05, 2017, 12:21:23 AM »
I also ordered an M-unit now from your recommendation! Cheers :)
Offline calj737
  • I refuse...
« Reply #119 on: January 05, 2017, 03:14:34 AM »
I am sure you will like it.  :D Now you just need to pony-up and get an M-Lock too  ;)
I looked back and didn't see any mention of it, but while your forks were apart, did you service the oil, seals, and/or upgrade the springs?
Offline cb750tr
« Reply #120 on: January 05, 2017, 06:49:48 AM »
I ordered their new unit, that comes with a Bluetooth connection to enable the ignition button as far as the motorcycle is in range. So, I won't bother with an M-Lock :)
Yeah, new oil, new seals, new bushings. Stock springs, as the CBR1000F has quite a bit stiffer ride stock. I'll evaluate (or rather, let someone who's a lot better at riding than me evaluate) and see how it is.
Offline calj737
  • I refuse...
« Reply #121 on: January 05, 2017, 08:01:38 AM »
Huh?
Offline cb750tr
« Reply #122 on: January 05, 2017, 08:23:05 AM »
Huh?
They've got a new M-unit soon launching, with Bluetooth built in. It comes with some new nifty functions, tracking distances, turning on / off the alarms and getting logs etc. But the best part for myself was using your smartphone instead of the key. Even if you've got an ignition lock, you can use the phone without needing the key (if I understood it correct).
« Reply #123 on: January 05, 2017, 09:17:53 AM »
Huh?
Any details on this new version of the M-Unit from a website, email or other source.  Sounds interesting, but I haven't seen anything about it on the Interwebs.
Offline cb750tr
« Reply #124 on: January 05, 2017, 09:23:03 AM »
Huh?
I'll send you a PM!
