Author Topic: Paint repelling surface?  (Read 744 times)
Offline Bodi
« on: May 14, 2016, 01:52:18 PM »
I've done a lot of painting and never seen this.
I'm trying gloss black Rustoleum epoxy appliance enamel, hoping to do a tank with it. I painted a lawnmower tank as a test.
This small tank was prepared by removing the old paint using a wire wheel, sanding with 100 grit then 600 grit, washing with soap and water, extensive rinsing, drying, wash with isopropyl, final wash with acetone.
After drying the paint went on quite nicely except...
Some spots repelled the paint, it just jumped back from the metal.
As far as I know no silicon was ever used on it, and the multiple different washing should have taken that off anyway?
It looks like a silicon problem but I can't figure how it got there.
Taking pics of shiny black paint is hard, but this shows sorta what happened - the silver parts are bare steel:
Any ideas on how to avoid this?
And: the epoxy paint, after curing one week, seems fuel-proof.
« Last Edit: May 14, 2016, 01:55:43 PM by Bodi »
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
Re: Paint repelling surface?
« Reply #1 on: May 14, 2016, 02:30:58 PM »
Primer coat first?  Just a guess.  I've never used rustoleums appliance enamel.
Offline Bodi
« Reply #2 on: May 14, 2016, 04:17:45 PM »
The can says not to prime it. Recoat is odd, within 30 minutes or after 1 week.
I've seen similar spots using "normal" spray paint where silicon or some mold release agent was involved, but after an acetone wash the problem did not repeat.
Offline Lostboy Steve
« Reply #3 on: May 14, 2016, 04:50:37 PM »
I had that issue with the epoxy hard paint a few times on fork lowers as well. If you strip them again, try misting on an almost translucent coat. Let it dry. Then do a second equally thin coat. Let that dry as well. The final coat can be "wet". This usually works for me.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline CB650CPastor
« Reply #4 on: May 14, 2016, 05:05:32 PM »
Yeah - definitely looks like some sort of surface contamination. I would think your cleaning process would have removed it though. Sometimes metal that has had oil on it for years can be hard to get clean... The metal can almost seem to 'weep' the oil even after you clean it off.
Tim
Current:1980 Honda CB650C Custom, 1969 Toyota Corona Deluxe Sedan
Past: '07 Honda Rebel 250, '80 Yamaha XS1100 Special, '69 Honda CB160, '67 K15 Suzuki Hillbilly, 1971 VW Super Beetle...
