Author Topic: Starter clutch/flywheel rotor woes  (Read 951 times)
Offline JDeSoto
« on: May 14, 2016, 09:23:03 PM »
Hey all,
I'm getting ready to replace my starter clutch and flywheel rotor in this next week or so. Any potentially helpful advice?
My ride is a '76 Cb750k
Thanks in advance!
Re: Starter clutch/flywheel rotor woes
« Reply #1 on: May 14, 2016, 09:40:51 PM »
The rotor may be spinning on the tapered end of the crank-shaft. If so, you may only need to tighten the bolt that locks the rotor to the crank.
« Reply #2 on: May 14, 2016, 10:20:38 PM »
Thinking you are going to replace the rollers, springs and caps?! Drill out the 'stakes' on the 3 screws then only use an impact driver on the screws.
Why replace the rotor? It's just a big chunk of metal that can not go bad. Maybe use a lighter model one if yours is of the heavier variety?
The bolt should be torqued to ~ 72 ftlbs.
If the mating surface for the rollers on the gear is very irregular you may consider replacing the gear.
An air impact would be VERY helpful.
Offline JDeSoto
« Reply #3 on: May 15, 2016, 01:05:17 AM »
It's sounding like I should just swap out the rollers, springs and caps after all. My issue is that when trying to start the bike up the starter gear doesn't engage - all I get is a crazy spinning sound. I'm hoping this will fix it because I'm dying to finally ride dammit!!
Offline JDeSoto
« Reply #4 on: May 15, 2016, 01:05:28 AM »
Thanks for the tips by the way.
