Author Topic: Header Exhaust Pipe Gaskets CB500  (Read 984 times)
Offline whitjonw
  • Motorcycle Maniac
« on: May 17, 2016, 05:41:43 PM »
I just scored a 4 into 1 header for my bike. Can I re-use the exhaust pipe gaskets or should I order new ones ? Just placed an order and forgot to add those to the order.....doh !
1973 Honda CB500 K2
1974 Honda CL200 Scrambler
1974 Honda CB750 K4
1976 Honda CB750 K6
This is our life, this is our song.....
Offline whitjonw
  • Motorcycle Maniac
Re: Header Exhaust Pipe Gaskets CB500
« Reply #1 on: May 18, 2016, 03:27:58 AM »
Will do....thank you.
1973 Honda CB500 K2
1974 Honda CB750 K4
1976 Honda CB750 K6
Offline Chachi
« Reply #2 on: May 18, 2016, 07:24:07 AM »
They're not exactly cheap... set of 4 around $16 from local Honda dealer for me. I'm sure eBay sellers have them as well. But definitely needed in your scenario. Sometimes you can get by not replacing them if you're taking existing headers off and on... some do it for oil changes for example. But if you're installing different headers, then definitely get new copper gaskets. Whenever I pull my header (not that often) I get fresh ones. Not worth fighting air leaks.
If you've never removed old copper gaskets... use a little force with a small flat blade screwdriver or strong pick. They can be hard to see all smashed up in the header port. You may have to use some force. Once you can get one spot separating, they usually pop off in one piece. The fresh ones should just sit in the port with no assistance while you re-fit your header. I've never had to use anything to hold the new gaskets in place while installing headers.
73 CB750 K3
72 CB500 K1 - Sold
75 MR50 Elsinore K1
Offline whitjonw
  • Motorcycle Maniac
« Reply #3 on: May 19, 2016, 07:00:17 PM »
Vintage CB750 has them in a package of 10 for $16.95. http://www.vintagecb750.com/products/7/exhaust
I either order from there or Southern Honda Powersports currently who has them for $2.40 each. http://parts.southernhonda.com/p/Honda_1973_CB500K2/GASKET--EXHAUST-PIPE/55021708/18291-MN5-650.html
Of course I screwed up when placing my order with SHP and forgot to add the exhaust gaskets to the order ! I don' have a local Honda dealer, so have to order online. Guess I'll have to think of some more stuff to order.....boo
1973 Honda CB500 K2
1974 Honda CB750 K4
1976 Honda CB750 K6
