Cheers, George.
Bill, I never checked my tach while stalling it up (would need more seat time to be able to add that to the focus). I basically held the brakes (eventually tried rear only, as the front drum is pretty weak anyhow and that freed up my throttle hand), brought the rpms up, and lifted off the rear brake to launch while trying to roll the trottle on slow enough to not stall it. Seems like maybe I should not even twist the throttle on launch until the bike gets a little momentum, so as not to bog...? They ran the bikes on a pro tree to even things out I guess, because there were only about 5 bikes and a sled so they ran us all in the same class. The pro tree was brutal, so I tried a deep stage in that run in the video. I might try a Friday night with it again when it's just time trials.
