Support the site. Your contributions keep this site running.
you can do somthing like this
have seen them as repareir kit. somvhere.?? you just drill and tap the hole..and put the rep part inn..glue it vith lockteit(it holds the brakefluid) i have testet it for some years..to be total shure it dont softens up..but its better make a kobber disc teighting.modd it a bit
A set of diamond coated bits for die grinder or dremel migh be able to cut through the ezout. Getting it out is needed before it can be drilled. I have used them before to do this. Shall I send you a bunch of them?Find out what Harrisluv charges for the caliper repair? It might be affordable.David
I wonder if the paint was either of the Rustoeum yellow spray paints or from can thinned? My 550 tank was donethat way by PO. It is going to be resprayed after it is put back on road and sorted.I like the silver gauges. Will look good with cream or white. Yellow bikes look good with chrome I think.
I'm following Larry, just haven't commented. Good to see you back at it!
This set of Vessel screwdrivers also came a couple days ago. There was a post for a Father's Day sale at 50% off on this site. I already have more than I need Snap On screwdrivers but the deal was too good to pass up so I sprung and glad I did. All these years I've been using Snap On #2 or 3 but these are so much better for our bikes, especially the ones with a built in impact. $33 was a great price for an awesome product
