Author Topic: CB400 Four, version 9.0 for ME I flip for 400 fours  (Read 30756 times)
Re: CB400 Four, version 9.0 for ???
« Reply #25 on: May 19, 2016, 09:00:37 PM »
Momo,
You can't standby and let one of these bikes be crushed, you must like raising the dead...
Is that a sulfur yellow?
You have something to keep your hands busy with now.
It might keep you out of trouble. ;D
Watching this one develop...
David
« Reply #26 on: May 19, 2016, 10:49:28 PM »
You're on a mission . . .
Offline MoMo
  • Ride like you're invisible
« Reply #27 on: May 20, 2016, 02:07:50 AM »
Momo,
David
It is a rattle can job not parakeet yellow, so I don''t know what it is but I do have a fondness for yellow 400 fours
one of my favorites
Hope all is well at your end David...Larry
Offline MoMo
« Reply #28 on: May 20, 2016, 02:16:07 AM »
Along with most any Mel Brooks movie and Airplane the Blues Brothers are my top of the line movies.
  It's a hundred and six miles to Philly,  I've got a full tank of gas, half a bucket of brains, it's dark, and I'm wearing sunglasses.
Welcome all.  I hope to do this old, neglected 400 justice...Larry
Offline MoMo
« Reply #29 on: May 20, 2016, 02:20:54 AM »
nice that the piston vas stuck in upper posision..so most of the bore is.. prob.. not rusted..a sqvz of aft and diesel and some heat..and it vill boil.. and free it up...dont use asetone and fire at same time ::)
I've seen videos where people actually light whatever solution on fire in an attempt to free the seized piston.  I have a spare cylinder but I removed the liners and sold them to a forum member.   Also, I have two sets of pistons stashed somewhere
Offline calj737
  • I refuse...
« Reply #30 on: May 20, 2016, 03:34:12 AM »
Kerosene or SeaFoam. Kerosene is far cheaper if you can source it locally.
Offline MoMo
« Reply #31 on: May 20, 2016, 04:47:04 AM »
I've used Seafoam to unseize.  The seller of the bike gave me Kroil, which is presently in the cylinder.   Are recommending putting kero in the cylinder and lighting it up???  thanks for your input....Larry
Offline b52bombardier1
« Reply #32 on: May 20, 2016, 04:55:02 AM »
Some high wattage heat gun heat around the cylinder can also work. Takes longer but less chance of catching something on fire.
Rick
Sent from my SAMSUNG-SM-N900A using Tapatalk
1971 School Bus Yellow Aermacchi H-D Sprint 350
1972 Candy Yellow CL100 K2
1972 Candy Jet Green Honda CB500
1973 Mighty Green ST90 K0
1974 Mars Orange CT90 K5
1975 Topaz Orange ST90 K2
1976 Shiny Orange CT90
2006 Honda Foreman 500 (restored)
Offline MoMo
« Reply #33 on: May 20, 2016, 05:16:35 AM »
Rick
I have a high wattage heat gun as well as a propane torch. thanks for posting...Larry
« Reply #34 on: May 20, 2016, 08:55:28 AM »
Rick
If the motor is out, who cares? Have you seen Cal's engine unseize cocktail??
Offline MoMo
« Reply #35 on: May 20, 2016, 03:44:34 PM »
Rick
motor still in frame with head off.  Haven't seen the cocktail
Offline calj737
  • I refuse...
« Reply #36 on: May 20, 2016, 04:55:45 PM »
A 4 hour long BBQ after months of MMO, Kroil and ATF/Acetone soaked. Finally gave up and yanked the motor, pried the head, and filled the jugs with Kerosene. Lit 'er up, stood by in the freezing snow and sleet and kept adding more until the rusty bast-ages finally gave way.
If the motor is still in the frame, SeaFoam is my recommendation. Heat guns won't do diddly on rusted metal inside of aluminum; too dissipated. Propane directly at the piston (if you have decent access) or SeaFoam. SeaFoam ignites, but is very low combustion so you don't get that "WOOSH!" when she fires up. In fact, a buddy who is a Deputy Fire Chief turned me onto using it as they do fill their entire fuel tanks with it on First Responder vehicles for safety issues (fuel tanks near raging fires...). Says it won't combust inside their tanks.
« Reply #37 on: May 20, 2016, 05:19:13 PM »
His cocktail can't beat my blend of diesel fuel, kerosene and alligator blood. This is Louisiana, after all.
Rick
Offline calj737
  • I refuse...
« Reply #38 on: May 20, 2016, 05:49:35 PM »
Rick
Ha! If you really want to release it, crank up the welder to about 200Amps on DC and touch her off. I'd like to see you puny alligators take that!!!!  ;) ;D ;D ;D
Offline MoMo
« Reply #39 on: May 20, 2016, 09:13:47 PM »
Only #4 is seized, it has been soaking in a mix of Kroil and Seafoam only a day-didn't budge one bit tonight.  I lit it up but not for long, when i get a chance I'll burn it for a couple hours.
Offline MoMo
« Reply #40 on: May 20, 2016, 09:47:07 PM »
Removed more parts after I got home from work.
notice the beautiful S-curve design of the overgrown brake line :P
Offline MoMo
« Reply #41 on: May 20, 2016, 09:51:28 PM »
 the standard headlight chip from not putting the lip on the rim under the shell.  Most every 400 I ever had had this piece broken off :(
Also the shell is damaged worse than I thought
Have a spare shell but it also has the standard missing piece
Offline MoMo
« Reply #42 on: May 20, 2016, 09:55:23 PM »
Tried firing up the stuck piston but did not realize I needed to torch it for several hours,
that is burning Kroil BTW...Larry
Offline MoMo
« Reply #43 on: May 20, 2016, 10:05:01 PM »
Notice the special custom made rear turn signal cushions, I think the PO should patent that design and market as I've never seen a finer product
Offline grcamna2
« Reply #44 on: May 20, 2016, 10:43:50 PM »
Momo,
David
Yeah buddy,you give this old girl that special touch Larry  ;) a 1977 model/yr. ?
« Last Edit: May 20, 2016, 10:50:49 PM by grcamna2 »
Offline zammykoo
    • @Mototam
« Reply #45 on: May 21, 2016, 08:08:10 AM »
Looking forward to see if the burning kroil works out for you. I released my stuck piston by tapping the jugs with a piece of wood and mallet, on where I felt were the beefiest/strongest parts of the aluminum. Took several times going back and fourth between the left and right sides to raise it evenly. This was after trying to torch the piston with map gas and soaking in marvel mystery for several months.
Offline MoMo
« Reply #46 on: May 21, 2016, 08:52:44 AM »
[/quote]
early production run 1001342.  If it were a 77 I doubt I would have been tempted to buy it
Offline MoMo
« Reply #47 on: May 21, 2016, 08:54:43 AM »
I've been smashing with a fairly large dead blow. 3 pistons free, only #4 stuck(and it is STUCK >:( >:()
Offline calj737
  • I refuse...
« Reply #48 on: May 21, 2016, 09:39:26 AM »
As soon as the fire goes out, splash some acetone in there. It should seep down onto the rings and work at the rust. Then, re-light it with SeaFoam.
Offline zammykoo
    • @Mototam
« Reply #49 on: May 21, 2016, 10:26:11 AM »
I feel your pain! My #3 piston was the last one to get unstuck. My method was to try and utilize the crankcase' weight as leverage by strapping the jugs to my makeshift mini gantry. I actually had 3 straps (2 not pictured for some reason) left, center, & right sides. I believe this really helped me get it off. Once strapped evenly distributing the weight, I hit the jugs upward with the wood/mallet. The engine is fully suspended an inch lifted off the cart at this point. I didn't have to smash that hard because with each hit, the engine weight helped sag it out slowly.
