Author Topic: Aftermarket head gasket kit - thoughts?  (Read 3133 times)
Offline zammykoo
    • @Mototam
« on: May 20, 2016, 01:54:52 PM »
Anyone have thoughts on this kit? I have a feeling most will say stick with OEM, but just curious!
http://www.ebay.com/itm/182106611516?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT#vi-ilComp
Offline mystic_1
  • 1970 CB750K
Re: Aftermarket head gasket kit - thoughts?
« Reply #1 on: May 20, 2016, 04:25:03 PM »
Googling "Top Line Gaskets", the first hit is JC Whitney.  Take from that what you may.
The head gasket doesn't seem like anything special, it's a plain fiber gasket, akin to the kind you find in the cheaper Athena brand gasket sets.
Being "new-old stock" I'd wonder about how it was stored, for how long, and how good the rubber bits still are.
I think I'm seeing a lot of "casting flash" on the valve cover gasket (the formed rubber one) so I'd question it's quality as well.
Personally I'd take a pass, if better options are available.  Gaskets and seals aren't something you want to cheap out on.
mystic_1
- John Augustus Shedd
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #2 on: May 20, 2016, 04:36:19 PM »
Stick with OEM.
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline setdog
« Reply #3 on: May 20, 2016, 09:35:37 PM »
I could never get an MLS head gasket to seal properly because the mating surfaces were not perfect, i had them decked once and didnt want to take more material off trying to get them perfect so I bought an OEM for my cb750 problem solved no leaks.
« Last Edit: May 20, 2016, 09:38:02 PM by setdog »
My toolbox consists mainly of hammers.
76 CB 200T. (sold)
75 CB 750 K5. (sold)
74 CB 750 K4. (current rider)
73 CB 750 K3. (build)
https://www.youtube.com/user/setdog100
Offline jamesw
« Reply #4 on: May 21, 2016, 03:19:36 AM »
When you guys says OEM, where are you buying then from? I need a new head gasket and was going to buy the MLS from cyclex.
72K-F 750 Cafe
75K 750 Cafe
75F 750 Restoration
Offline DaveBarbier
« Reply #5 on: May 21, 2016, 05:42:05 AM »
For your 350f? In your signature it would be nice to put what type of bike you've got so people don't have to ask. Or just mention it in the first post.
I'm seeing these two gaskets on ebay:
https://www.ebay.com/itm/301940790435
Also, David Silver might be able to get a head gasket:
https://www.davidsilverspares.com/parts/by-part-number/part_12251333306/
As far as the other rubber bits, I've used a mix of OEM and Vesrah but if I were to do it again I'd spend more time sourcing the individual OEM bits, can't beat 'em. Use CMSNL.com or Partzilla.com and find the part numbers you need.
Offline Lostboy Steve
« Reply #6 on: May 21, 2016, 06:54:49 AM »
Which is why I am running the Graphite Vesrah. Nothing wrong with it. Plenty of Small block Chevy's are doing wheel stands with graphite head-gaskets.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline zammykoo
    • @Mototam
« Reply #7 on: May 24, 2016, 02:39:34 PM »
I appreciate all of your input! And mystic_1, you've guessed it. The seller told me the base gaskets are a little stiff and the valve guide seals are no good.
I'll keep an eye out for OEM parts, although I'd like to just get a kit that includes everything I need. I'm looking to replace all top end gaskets. What's by best option here?
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #8 on: May 25, 2016, 03:47:23 PM »
I learned my lesson, OEM all the way. Unless you really enjoy working on your bike more than riding it.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
« Reply #9 on: May 25, 2016, 04:25:38 PM »
+1...and if you really can only scrounge up one oem gasket, do make it the head gasket
Offline SKOL
« Reply #10 on: May 25, 2016, 07:11:15 PM »
CycleX gasket kit
Offline fizzlebottom
« Reply #11 on: May 26, 2016, 10:58:23 AM »
+1 for OEM. Here's why:
I just finished rebuilding the top end of my CB650SC. The old gasket was a nightmare to remove, but I ended up getting it decked anyways. I managed to clean the cylinder block deck just fine, but didn't have it decked. I know there were imperfections, though relatively minor. I originally bought a cheap gasket and found that it didn't fit properly at all. I quickly found an OEM gasket, used some copper spray on it just to make sure it'd seal, and buttoned everything up. The motor has been oil tight so far.
OEM is the way to go if you can't find a HIGH QUALITY aftermarket (Cometic, etc.).
1982 CB650SC Nighthawk
Offline zammykoo
    • @Mototam
« Reply #12 on: May 26, 2016, 12:31:03 PM »
cycleX doesn't seem to have a set for the 350  :(
It looks like the general consensus is OEM (which is normally my first choice too) but I am a little confused about this. I see some OEM gaskets on ebay but most are NOS. Does Honda even make gaskets for our bikes anymore? Wouldn't I be taking a chance to getting NOS if the gaskets/seals were not stored properly? Or what's a reliable source for OEM?
« Last Edit: May 26, 2016, 12:34:29 PM by zammykoo »
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #13 on: May 26, 2016, 01:32:26 PM »
+1 on the copper spray. I never saw another oil leak from the between the head and the jugs again.
1974 CB360T
2015 BMW F700GS
  __o
_- \_<,
Offline beemerbum
« Reply #14 on: May 26, 2016, 04:02:55 PM »
I've had good luck with David Silver Spares for OEM head gaskets
Offline SKOL
« Reply #15 on: May 26, 2016, 09:05:08 PM »
Permatex aviation form-a-gasket is nice for some extra insurance, regardless of quality of gasket.
Offline grcamna2
« Reply #16 on: May 26, 2016, 09:21:56 PM »
Vesrah is comparable to OEM Honda gaskets and if you can find a complete Vesrah Made in Japan kit you won't be disappointed. imo
« Reply #17 on: May 27, 2016, 12:03:45 AM »
Vesrah? -1 totally   copper spray?  +2 totally      dudes...you can order oem Honda parts all day long, online!  Kaws, Suzis, Yamis?...not so much.  Don't take that #$%* for granted.  These bikes are 40+ years old!
Offline zammykoo
    • @Mototam
« Reply #18 on: May 27, 2016, 04:31:40 AM »
Thanks all, this definitely helps! Not sure how I missed DaveBarbier's post above earlier. I'll try and piece as much oem as I can find, and the rest Vesrah. You guys are awesome :)
Offline DaveBarbier
« Reply #19 on: May 27, 2016, 04:52:12 AM »
Vesrah? -1 totally
+1...wait or -1, whichever means I agree with Sean.
A few o-rings on my 550 build by Vesrah failed within 6 months. Although many are still good. As long as the OEM are available why cheap out?
I remember Hondaman talking about the OEM head gaskets and how they're impregnated with a sealer and set once heat cycled. They go on dry, no added sealer.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #20 on: May 27, 2016, 05:07:14 AM »
All this talk about "OEM" head gaskets, where do you get an "OEM" head gasket for CB750 cylinders bored to 65mm (836)?  ???
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline zammykoo
    • @Mototam
« Reply #21 on: May 31, 2016, 05:34:08 PM »
Well lookie what just came in the mail today  ;D
I was a bit skeptical of the condition of the rubber bits but they feel soft and supple. I think the vacuum seal kept the moisture in well.
Offline grcamna2
« Reply #22 on: May 31, 2016, 06:34:14 PM »
Nice  8)
Offline mystic_1
  • 1970 CB750K
« Reply #23 on: May 31, 2016, 08:42:40 PM »
Get a bright light and a magnifying glass, and stretch the rubber parts a bit and inspect for fine cracks.  If you don't see any they're probably good to go :)
mystic_1
Offline zammykoo
    • @Mototam
« Reply #24 on: May 31, 2016, 09:42:59 PM »
mystic_1
Will do. Thanks for the tip!
