Author Topic: any electricians on this forum  (Read 1485 times)
Offline dusterdude
« on: November 17, 2006, 06:53:57 AM »
i need to know how to run a 10-3 wire with a ground to my wall oven.any help on this?
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline tramp
Re: any electricians on this forum
« Reply #1 on: November 17, 2006, 01:54:18 PM »
220 or 110?
1974 750k
Offline jbailey
« Reply #2 on: November 17, 2006, 07:27:46 PM »
10-3 romex is only good for 30 amps.  Are you sure that is all you need?  What do you need to know specifically?
1975 Honda CB550K
2005 Kawasaki ZG1000 Concours
« Reply #3 on: November 18, 2006, 06:31:24 PM »
I think you would do well to run a 12-3 cable directly from the box to a dedicated 30 AMP breaker if you have an open spot in the box.
Offline bigmak
« Reply #4 on: November 18, 2006, 08:32:53 PM »
12-3 is only rated for 20 amps, code violation to hook to a 30 amp breaker. Does your oven have a 3 wire or a 4 wire plug. You need to match the breaker and wire size to the outlet. The outlet you use depends on the cord on the oven. Give more info and you will get a better answer.
Offline Jonesy
  • Shop Rat
« Reply #5 on: November 21, 2006, 07:11:29 PM »
LOL.. That mantra never gets old on this board (it is true, though).
Offline mrbreeze
  • Not your average
« Reply #6 on: November 21, 2006, 07:53:09 PM »
Duster....I mentioned this thread to a good bud of mine that is a highly paid union electrician. He has been in the trade for 20+ years. The first thing he told me was.....Whatever info someone gives you here...right or wrong.....who catches hell if your house burns down? This made perfect sense to me. I would play it safe and pay a licensed electrician (just an opinion).
MEMBER # 257
Offline Bodi
« Reply #7 on: November 22, 2006, 08:13:21 AM »
Get an electrician to do it. If you have to ask "how" here then you shouldn't be considering doing it yourself. This is not something to mess with as mistakes could kill you on the spot (ZAP!) or burn your home down later.
You may be required by your local building codes to have such work done by a licensed tradesman.
Online SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
« Reply #8 on: November 22, 2006, 08:27:09 AM »
This is where having a 240V 30A ring main in your house pays dividends.
Long live British Standards !!  (but don't tell Terry in Oz or he'll start off about the cricket again)
SOHC4 Member #2393
1971 CB500K0 (US Model)
All modern bikes now gone...
Offline dusterdude
« Reply #9 on: November 22, 2006, 08:31:44 AM »
thanks for the replies,i may have an electrician do this.
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Offline cb650
« Reply #10 on: November 23, 2006, 06:09:24 AM »
1st rule of electrical work stand in a bucket of water ;D.
                    Terry
Offline Kevin D
  • SE Michigan
« Reply #11 on: November 23, 2006, 07:51:50 AM »
My 40 year old General Electric built-in range recently blew the main feed open (inside the range). It blew a hole the size of a dime through the sheet metal at the back of the range and also scorched the wall. It was #14 (!!!!) hi-temp wiring. The elements were wired with #16, also hi-temp. The breaker at the panel is 40A 240v. The feed from the breaker panel to the range is #8. I think I read 12.5kw on the range. All of this tells me that the main wire is working awfully hard. Sooooo - I went to the Servall appliance parts and found that they had #12 for main and #14 for elements (all hi-temp rated).
I also had my wife shopping for a new range but she couldn't come up with one to fit the opening, which meant a new range means a new kitchen at $25000 or so. We opted for the replacement range wiring.
Today being Thanksgiving, the range is getting a 7 hour Turkey Test, plus potatoes, dressing, casseroles, pies, you name it, we will be cooking it today. If the range holds together, I will be truly thankful.
71 CB750 K1
108,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
Offline Bodi
« Reply #12 on: November 23, 2006, 08:09:45 AM »
Wire sizes inside an appliance don't relate to the wire size needed for the supply cable. You can use a #14 wire for 30 amps provided it has high temperature insulation and air circulation; for wires in a cable for in-wall installation you have 2 current carrying wires (twice the heat) and the cable insulation keeping heat in plus the cable may be in small holes drilled through wooden beams with no air cooling and plenty of combustible wood adjacent. So power cable specs are pretty conservative. For good reason.
If you know what you're doing then installing wiring yourself is no big deal. Like others have suggested, I don't want to give you any instructions because I don't know you and your abilities. You could kill yourself or burn your house down pretty easily.
