Author Topic: Mouse Balls  (Read 769 times)
Offline RevDoc
Mouse Balls
« on: May 22, 2016, 06:27:25 AM »
NOTE: I don't know how anyone could write this with a straight face! This was an actual memo sent at an unnamed computer company to its employees. It went to all the company's field engineers, and it was in regard to a computer peripheral problem. The author of this memo was quite serious; the engineers rolled on the floor! (Especially note the last sentence!)
INSTRUCTIONS FOR REPLACING MOUSE BALLS
Mouse balls are now available as FRU (Field Replacement Unit). Therefore, if a mouse fails to operate or should it perform erratically, it may need a ball replacement. Because of the delicate nature of this procedure, replacement of mouse balls should only be attempted by properly trained personnel.
Before proceeding, determine the type of mouse balls by examining the underside of the mouse. Domestic balls will be larger and harder than foreign balls.
Ball removal procedures differ depending upon the manufacturer of the mouse. Foreign balls can be replaced using the pop-off method. Domestic balls are replaced by using the twist-off method.
Mouse balls are not usually static-sensitive. However, excessive handling can result in sudden discharge.
Upon completion of ball replacement, the mouse may be used immediately. It is recommended each replacer have a pair of spare balls for maintaining optimum customer satisfaction. Any customer missing his balls should contact the local personnel in charge of removing and replacing these necessary items.
Dana
'78 CB550K--Angie
'82 CB750 Custom--Eva
As soon as you straddle a bike expect every other driver on the road to suddenly start competeing for the title "Dumbestsonofa#$%*inallNorthAmerica!!"
Offline dusterdude
Re: Mouse Balls
« Reply #1 on: May 22, 2016, 09:56:43 AM »
Ill be damned
Sent from my LG-D850 using Tapatalk
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Re: Mouse Balls
« Reply #2 on: May 23, 2016, 05:16:28 AM »
That used to be the office prank - taking the ball out of a mouse.
