Author Topic: How to get these battery terminal nuts/bolts in?  (Read 2364 times)
Offline juntjoo
« on: May 24, 2016, 01:02:34 AM »
I don't know if my battery just happens to be bulky or this is just how it is or I'm just missing something but I don't have fat fingers and I can't get a hold on anything in there, especially with no play in the thick and stiff cables. Help?
-Ben
82 Nighthawk 650..
1982 Honda Nighthawk...
I HAVE A 1982 HONDA NIGHTHAWK FFS! j/k. It's my only bike, my first and last.
Offline MickB
Re: How to get these battery terminal nuts/bolts in?
« Reply #1 on: May 24, 2016, 01:37:18 AM »
Junt there's a cradle for the nut hold it with your finger, next get a Philips head and screw it into the nut. It's tight but doable.
Offline Steve_K
« Reply #2 on: May 24, 2016, 04:45:17 AM »
I have put a rubber gas line behind the nut to hold it in place.  Keeps the nut in place while starting the bolt.  Also just used a finger to hold in place.  This on a 550 and 750.
Steve
Steve_K
Offline Deltarider
« Reply #3 on: May 24, 2016, 04:59:48 AM »
Position the nut, then slide a flat blade screwdriver behind it, pressing towards the bolt. Thread the bolt, then wedge the nut in place until you're done.
If you follow this, try to avoid the screwdiver to touch the frame in case the negative terminal is already connected. ;D
Make it a habbit when installing a battery to connect the positive terminal first and when removing to disconnect the negative first.
« Last Edit: May 24, 2016, 05:02:49 AM by Deltarider »
CB500K2-ED Excel black
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=01bnjvq3iag3chi17mv12ikr87&/topic,60973.0.html
« Reply #4 on: May 24, 2016, 06:31:20 AM »
+ 1... for the gas line.
.i also cut a small piece fuel line..and press it behind the nut.
.it holds fine..and damage not the battery housing id the schrev is a bit to long..
i hate all this v-w.... vords
« Reply #5 on: May 24, 2016, 09:37:54 PM »
+4 on the gas line my brother showed it to me.
Offline juntjoo
« Reply #6 on: May 26, 2016, 04:57:09 PM »
Thank you all. Sounds like you've all got the tricks. I'll very to tha it later then report back
-Ben
82 Nighthawk 650..
Offline beemerbum
« Reply #7 on: May 29, 2016, 08:07:43 AM »
Please don't use that liquid acid filled rust manufacturer and destroyer of battery boxes. AGM is the only way to go unless it is a show bike and originality is important.
Offline Swoop
« Reply #8 on: May 29, 2016, 09:21:57 AM »
I have found that the clear battery vent line works well behind the nut as well and always seems to be around.
« Reply #9 on: May 29, 2016, 09:50:56 AM »
 If you cant find that just use a straw or rolled up paper or cardboard...
Offline juntjoo
« Reply #10 on: June 20, 2016, 11:09:12 AM »
Thanks. You may have saved my life. I was wondering about this.
Anyway, actually, the real trick, for me at least was to lower the battery in there only about 90% the way down there(it's tight down there and it stops against something, for me at least) leaving some finger room to maneuver the nuts on without any extra makeshift instruments.
-Ben
82 Nighthawk 650..
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #11 on: June 20, 2016, 11:17:01 AM »
DO NOT USE SUPERGLUE
Just dont, it's a long story.
Offline juntjoo
« Reply #12 on: June 20, 2016, 01:44:07 PM »
Okay, promise. But why would you?
-Ben
82 Nighthawk 650..
  • Holy Cow! I'm a
« Reply #13 on: June 20, 2016, 02:03:12 PM »
Was lookin for an easy way to hold the fastener for an 87 zuki battery.
And thats the beginning of a long series of headache
