Author Topic: Possible parts hoarding-compatible parts swapping 77-78 550s  (Read 987 times)
Offline b1jackson
I have a lead on a 78 parts bike with a bad engine and the easily swappable parts between a 77 and 78.  Are main parts like starters, carbs, etc. compatible.  I imagine only a few cosmetic changes between these years but can't locate any info on specifics.  For $100, would it be worthwhile as these bikes are abit scarce in my area.  Mufflers are toast and so is seat.
Old Honda Rescue Centre
ohrc_vintagemoto on Instagram
Offline Mantree
Re: Possible parts hoarding-compatible parts swapping 77-78 550s
« Reply #1 on: May 24, 2016, 06:14:56 PM »
For $100 I'd say it's worth it I just got the carbs
Sent from my ME302KL using Tapatalk
Offline DaveBarbier
« Reply #2 on: May 24, 2016, 06:28:47 PM »
Very similar. Carbs are different. PD46c in the '78, PD46a in the '77. They should be able to work though with proper jetting. I'm pretty certain spacing is the same.
$100, I'd get it even if most parts weren't compatible.
Offline Mantree
« Reply #3 on: May 24, 2016, 07:46:55 PM »
They will fit the engine but not the airbox
Sent from my SM-G900V using Tapatalk
Offline DaveBarbier
« Reply #4 on: May 25, 2016, 03:44:52 AM »
Dang, thanks a bummer
Offline Deltarider
« Reply #5 on: May 25, 2016, 03:54:58 AM »
Why not consult the parts list? http://www.honda4fun.com/pdf_parts_list/pdf_spac500-550/CB500-550_K3-K4.pdf On p.72-3 I see no indication airbox differs.
CB500K2-ED Excel black
Offline b1jackson
« Reply #6 on: May 25, 2016, 04:25:38 AM »
Awesome.  Thank you.
Offline Mantree
« Reply #7 on: May 25, 2016, 05:22:08 AM »
I had a 72 with late models carbs that had pods because the carbs had a larger diameter on the intake side
Offline Deltarider
« Reply #8 on: May 25, 2016, 06:28:06 AM »
Yes, but his is a CB550K3 and CB550K4 parts are compatible.
Offline Lostboy Steve
« Reply #9 on: May 25, 2016, 07:03:47 AM »
Ill take the bad engine.  ;D
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline Bankerdanny
  • Endeavor to persevere
« Reply #10 on: May 25, 2016, 07:43:40 AM »
The airbox on 74-76 550's is different than the 77-78. The '78 carbs are externally identical to the '77 carbs and should swap right in. You shouldn't even need to change the jets, although in general the 77-78 bikes were tuned a bit leaner than the earlier bikes in response to changes in emissions requirements.
Offline Mantree
« Reply #11 on: May 25, 2016, 01:50:53 PM »
By bad I didn't realize we were talking 550s
« Reply #12 on: May 25, 2016, 05:57:21 PM »
I was able to use the airbox cover off of a 75 on my 77 though. It isn't perfect but it's better than not having one.
www.lostboysatomicgarage.com
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline Bankerdanny
« Reply #13 on: May 25, 2016, 07:20:37 PM »
Its the plenum that connects to the carbs that is different. The spacing and the connectors. The actual filter housing is probably adaptable.
