Author Topic: CR carby questions  (Read 1130 times)
Offline Scott
  • 72 CB750
CR carby questions
« on: May 27, 2016, 01:37:39 AM »
G'day, how's it going
What do you put on the thread of the aluminum  adapter that connects the carbys to the inlet rubbers.
Please and thanks
Scott
Offline turboguzzi
Re: CR carby questions
« Reply #1 on: May 27, 2016, 02:49:27 AM »
nothing in my case..... there should be a thin o-ring in there, #5 in the pic
Offline Scott
  • 72 CB750
« Reply #2 on: May 28, 2016, 01:24:18 AM »
Cool ta.  I just licked the ring and screwed it.
Sounds about right doesn't it?
Do you have a standard petcock.  If so how did you go from the petcock size fuel line to the carby size.  Maybe 6 to 8mm
Thanks for your time
Scott
« Reply #3 on: May 30, 2016, 10:15:57 AM »
 One of mine has shrink tube over the poly fuel line, shrunk it down and holds it tight.
Offline Scott
  • 72 CB750
« Reply #4 on: May 30, 2016, 11:30:59 AM »
Thanks Don
I looked on ebay last night and with the correct wording I found a straight through adapter that goes from 6mm to 8mm.  I also ordered a 6mm T to get both my 6mm fuel lines into 1 before I adapt it to 8mm.  I bought a selection of plastic and brass so hopefully I can make something out of it.
Have a good one
Scott
Offline turboguzzi
« Reply #5 on: May 30, 2016, 11:55:33 AM »
that easy, slip a piece of thin tubing over the 6mm fitting, and the 8mm tube over it. done :)
