Author Topic: Backfiring / Timing / Carb issue CB750 - Help!  (Read 25892 times)
Offline jodangler
Re: Backfiring / Timing / Carb issue CB750 - Help!
« Reply #125 on: July 14, 2016, 09:18:39 PM »
if you are sync'ng your carb with gauges you might want to calibrate your gauges to make sure they are all measuring the same. another thing that comes to mind that you could check would be the float plungers with the little filter/screens, maybe the little screens are blocked or the plunger are stuck or wrong size and check to c if  u have a clean fuel tank it could be dirty/rusted/kremed-lined.  its all a guess.
if your rubber boots are new maybe you dont have them clamped down if not you should really inspect them for fine hair cracks and if they are old maybe you need to re-soften to get a better seal...
Offline g8ts
« Reply #126 on: July 26, 2016, 10:07:31 AM »
Update? 6 pages of replies, I need an update of how this progressed?
Thanks
"rebuild it rebuild it and rebuild it"
quote from 30 year old Honda owners manual.
Good thing though, its good for another 30 years.
78 550 gone sent to friend in Germany
72 750 brown
73 750 Red
74 750 green
74 750 strange color extended forks
75 750 blue
75 500t sold
75 360 cl orange
77 750ss black
82 900c blue
83 650 CX black
Fence and herding dog to keep them all in.
Offline jodangler
« Reply #127 on: July 27, 2016, 07:27:29 AM »
I was tuning my carbs yesterday to give my bike a tuneup and noticed that my gas wasn't flowing properly down to my carbs and thought this could be something for you to look at so what I have read in other post is that if your carb vent tubes are clogged you can get a vapor lock symptom which would give you the problems you r experiencing. I don't remember if it was covered already but you could also do  a clear tube check to c where your gas sits inside your carbs to make sure you have enough gas to run your bike. I attached some pics for ref... You might also want to check this website for more info it helped me out and it might help you to... http://www.hondachopper.com/garage/carb_info/carb_info.html
« Reply #128 on: July 27, 2016, 11:52:38 AM »
I had a long lasting problem due to one bad ignition wire. Sometimes it acted as too rich, sometimes as too lean. I tested a lot of carb jetting until the intermittent wire problem became less intermittent and I could not miss it.
The ign wire was new and I could not dream about a faulty wire.
Thats why I earlier recommended to swap the entire ignition set, only as a fault tracing routine.
« Reply #129 on: October 11, 2016, 02:54:18 PM »
I don't remember if it was covered already but you could also do  a clear tube check to c where your gas sits inside your carbs to make sure you have enough gas to run your bike. I attached some pics for ref..http://www.hondachopper.com/garage/carb_info/carb_info.html
Waaaay to low in your bowl there jodangler  :o
« Reply #130 on: October 11, 2016, 02:59:45 PM »
When i vacuum synced my carbs again this weekend i was also working with the air screws.  It seems that when closed them (rich) they didnt stutter or really respond at all.  When i started to turn them out past 2 turns the idle actually sped up.  Pilot jet #40 Keihein - clean.  Does this help indicate a lean circuit?
These air screws need to be set and then left alone.
They are set based on Air/fuel ratio....or plug color, if you dont have access to an O2 sensor.
get them dialed in, and then leave them alone.  the only thing to adjust in a vacuum sync are the slide adjusters and their lock nuts.
Please state again what the main symptom or issue you continue to have....
Thanks....
Offline gypsywind
« Reply #131 on: October 18, 2016, 04:21:50 PM »
make sure the advanse weights are not sticking or wore out its happened to me before
Offline BestBoy
« Reply #132 on: August 26, 2019, 03:46:06 PM »
So... after 6 pages... no solution after 3 years?
