Author Topic: 78 CB 550K motor rebuild  (Read 61683 times)
Offline DaveBarbier
Re: 78 CB 550K motor rebuild
« Reply #100 on: November 05, 2016, 06:33:09 AM »
So are you putting that pin/dowel back in where ever it came from?
Offline SF
  • I burn gas very well
« Reply #101 on: November 05, 2016, 07:10:24 AM »
Great job cleaning up the cases
92 wr250 sold
98 zx6r sold
04 zx10r
73 cb350 twin
75 cb550f
75 cb550f
72 r5c
rgid springer bobber project
« Reply #102 on: November 05, 2016, 07:58:48 AM »
I did that. ;D ;D That pin is a set pin for one of the transmission bearings...it keeps it from trying to spin in the cases. One hole is on the left about the fork shaft on the left. There is another on the right lateral to the shift drum. There should be 2 pins
« Last Edit: November 05, 2016, 08:02:52 AM by MRieck »
Offline AlekStooge
  • can't afford cheap stuff
« Reply #103 on: November 05, 2016, 08:29:17 AM »
Mike did a great job! I will take a look at that transmision bearing when I get home. Hopefully seal everything up tonight.
Offline DaveBarbier
« Reply #104 on: November 05, 2016, 09:07:03 AM »
Thought you dealt with the tranny bearing locating dowels. I assumed these were different.
Yeah, I'm not surprised that they look that good. I'm lucky enough to know of Mike's work first hand :))
« Reply #105 on: November 05, 2016, 10:33:19 AM »
Yeah, I'm not surprised that they look that good. I'm luck enough to know of Mike's work first hand :))
I was looking at the last pic and the locating pins holes are empty which prompted my response. I remember taking them out (they can be difficult with the suction created by oil).
 I'm the lucky one to have you fellas on the forum that send me your parts.....it is always appreciated and I strive to do the best job possible! ;)
Offline AlekStooge
« Reply #106 on: November 05, 2016, 10:59:14 AM »
Well hang, now I take a second look at your post. I actually set those two aside in a baggie because they fall out when I was moving the case around. That pin looks like those but I'm 99.9% it is not because there is only one and I remember setting those aside. Tripple checking when I get home.
« Reply #107 on: November 05, 2016, 11:28:49 AM »
Me, too.  Mike's work is second to none.  Everything he does for a customer he does like he's doing it for his own bike with high quality work and meticulous care.
« Reply #108 on: November 05, 2016, 02:04:06 PM »
Thanks brother. Much appreciated. ;) Is it part #37 on this fiche?
http://www.cmsnl.com/honda-cb550k-1978-usa_model7222/partslist/E++15.html#results
Offline AlekStooge
« Reply #109 on: November 05, 2016, 05:37:10 PM »
Aww man I thought that was it but that was already there.
Offline AlekStooge
« Reply #110 on: November 06, 2016, 02:56:52 PM »
Wow I don't know how this happened but that pin goes into part number 8 and is part 10.
http://www.cmsnl.com/honda-cb550k-1978-usa_model7222/partslist/E++16.html#results
I was pulling the primary shaft when that pin flew out at me and that is in the lower case not the upper like the shift drum shaft??? I noticed only four pins and didn't see a space for the fifth so it most go in there. Photo 1
Anyways couple of things. I going to refer to the photos in this post.
Is the pin in the top right (photo 2) supposed to stick out to block the sprocket star (photo 3)?
Is there a certain way the sprocket needs to sit when installed?
Part 24 appears to be missing unless it's recessed somewhere and I can't see it but that pin appears to not be there (photo 4). I don't see how it could have fallen out. http://www.cmsnl.com/honda-cb550k-1978-usa_model7222/partslist/E++14.html#results
Offline AlekStooge
« Reply #111 on: November 09, 2016, 05:43:16 PM »
Nevermind I was mistaken. That pin that belongs in the hole was attached to the shaft. I'm trying to get the other pin out now.
I decided I'm going to move on.
Offline DaveBarbier
« Reply #112 on: November 09, 2016, 06:45:30 PM »
Did you figure out where that dowel/pin is supposed to go?
Offline AlekStooge
« Reply #113 on: November 10, 2016, 09:18:41 AM »
I didn't. Honestly can't find what it could have been.
Offline DaveBarbier
« Reply #114 on: November 10, 2016, 09:58:34 AM »
Did you measure it with calipers in metric?
Offline AlekStooge
« Reply #115 on: November 11, 2016, 05:39:41 AM »
I measured in inches then converted it to metric. I don't have calipers or measuring metric tape. I converted it from a quarter inch to 6.xx.mm. I don't remember the exact measurement but it was 6mm.
Offline DaveBarbier
« Reply #116 on: November 11, 2016, 05:51:37 AM »
Ok, well if it were me I'd have measured it with my metric digital calipers and then taken to the parts fiche to then rule out the obvious. Then anything that's similar I'd open up and check.
I, along with most (all?) of the forum I'm guessing, am completely against leaving parts out of a rebuild. If you're comfortable with leaving small bits out and feel the bother of trying to find out what part this is is worse than the chance of a motor not working correctly once buttoned up and having to split the cases and deal with the possibility of broken bits, then by all means, onward and upward.
Offline AlekStooge
« Reply #117 on: November 11, 2016, 07:51:13 PM »
Dave you absoultly make a lot of sense. I took the time to look at each parts fiche that are in or nearby the cases. I will try one more time, maybe I'll write all the parts numbers and place that part next to it.
Offline AlekStooge
« Reply #118 on: November 13, 2016, 07:14:32 PM »
I've looked at everything over again and even bought calipers. I don't see anything that is 4X7 in any of the parts fiches. Really scratching my head here.
Number 24 is missing so I'll have to order it. http://www.cmsnl.com/honda-cb550k-1978-usa_model7222/partslist/E++14.html#results
You have to take a circlip off to get to where that part sits. I only just recently took that apart and didn't see it sitting in there. No idea how that could happen.
Offline DaveBarbier
« Reply #119 on: November 14, 2016, 04:37:12 AM »
I can't think of anything else other than maybe the sprocket cover alignment dowels?
Calipers are good to have, you'll be happy you own them :)
I've been looking through the schematics for your bike too, haha. It doesn't help that not all dowel pins/knock pins aren't labeled with a measurement. I'll keep thinking...
Offline DaveBarbier
« Reply #120 on: November 14, 2016, 04:47:10 AM »
I'm not even sure what #24 does in that diagram. Does it align parts #11 & #5?
Offline AlekStooge
« Reply #121 on: November 14, 2016, 04:45:38 PM »
24 is a head scratcher. Like I mentioned there is a circlip keeping all those peices together. I open it up and no 24. I didn't drop it on the ground either. ??? ???
Offline AlekStooge
« Reply #122 on: November 17, 2016, 11:33:17 PM »
This question is particulalry geared towards Mike. By any chance did you included 3 different sets of the same dowel? I have one that came with spark plugs, I'm guessing that's for the head. The other set of the same size would be for the cases and I already have one for the block which is a different size? Also anyone know where this clip could go not seeing anything thats is half shapped like this one?
Offline DaveBarbier
« Reply #123 on: November 18, 2016, 04:23:40 AM »
Can't tell the size, but are they all solid? The dowels for the cases and cylinders are hollow.
The one on the left, just because of the rust characteristics, looks like it goes between the head and valve cover.
Edit: Did you bag and tag every single little part during the teardown? I can't think where an e clip like this would go.
Offline AlekStooge
« Reply #124 on: November 18, 2016, 05:28:14 AM »
You're right the one on the left was with the spark plugs so yes it's the one in between the head and valve cover. Based on the photo I can assume the darker one is the one in between the cases.
They are all the same size when you put them up against each other.
I bagged and labeled lots of parts but I guess I didn't do a good enough job doing it.
What I'm most surprised about is I can't find these in part fiches. I look through them a couple times before I ask you guys.
