Author Topic: 93 CB750 Nighthawk intermittent power loss and bucking  (Read 1604 times)
Offline PhilFloyd
« on: May 28, 2016, 10:35:26 AM »
About 6 months back I bought a 93 Nighthawk from my neighbor. Everything had been running great until I started to prepare the bike for a long trip.
Recently I have encountered a problem where the bike intermittently loses power then lurches forwards. This happens a few times then the bike will either stall or require choke to run. I took the bike to a mechanic who diagnosed the issue as dirty carbs. I got the carbs cleaned out and the problem still occurs. Called the mechanic back and he said he'd taken riden it around with no problems, but if I am still having the same issue it could be the fuel petcock and/or debris in the tank. I thought the issue might be electrical (bad coils or loose connections), but as I took off the gas tank today, fuel poured out of the petcock even though it was set to the off position. A couple of minutes later I picked up the tank and more fuel dripped out. If I am not mistaken, there should not be any fuel in the petcock as the cb750 has a vacuum operated valve. I disassembled the petcock and it was full of fuel, but there is not visible damage to the rubber gaskets inside. Are there any other issues that could be causing the lurching and power loss or should I go ahead and replace the petcock?
Offline grcamna2
Re: 93 CB750 Nighthawk intermittent power loss and bucking
« Reply #1 on: May 29, 2016, 06:06:19 AM »
The petcock may need to be rebuilt.
Offline kaptainkid1
« Reply #2 on: May 30, 2016, 09:33:50 AM »
Bad condensers and coils usually never break. Coils never break....
Sent from my SM-G386T1 using Tapatalk
1975 Honda CB750F Daily Rider
1974 BMW R90S Barn Find
1995 BMW R1100GS Dual Sport Daily
1996 Triumph 900 Adventurer Bobber
Offline Alan F.
« Reply #3 on: May 31, 2016, 04:09:11 PM »
The vacuum petcock sounds faulty to me. I used to run my Nighthawk's float bowls dry by turning the petcock off when I was nearing home, next time out I always gave it a few minutes to fill them back up after cranking the engine over to pull vacuum on the petcock. Then it'd start easily.
If fuel flows with the petcock off, it's in need of attention.
