Author Topic: 750 4  (Read 1355 times)
Offline Weathervaneman
750 4
« on: May 28, 2016, 03:25:48 PM »
Hi I'm just another old road warrior who recently inherited a 1971 750 CB. It is a late friend of mines bike. I've ridden Davidsons since the early 80s. My ride is a 78 Evo powered 4 speed kick start only Choppa
That is fast and loud it's been taking my abuse 8 years now. I got the 71 running today. It seems to get really hot in a short period of time. Peace 2 U
Weathervaneman.
Re: 750 4
« Reply #1 on: May 29, 2016, 10:56:17 PM »
Weathervaneman.
Maybe try this: change the oil to 20w50 Castrol 4T Motorcycle Oil and give it another try. These bikes are oil-sensitive, and too-light oils or those without zinc (and with too much detergent, like "V-Twins" oils) will cause many troubles.
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
Re: 750 4
« Reply #2 on: May 30, 2016, 04:40:15 AM »
Welcome to the forum! Pics of the chopper?
I want to find an old Evo...
And listen to HondaMan. He's the man!
--Evan
1975 CB750K "Rhonda"
Offline chewbacca5000
  • I polish covers!
Re: 750 4
« Reply #3 on: May 30, 2016, 05:13:26 AM »
Welcome!  I am finishing up a refresh on my 71k over the next few days myself.
Re: 750 4
« Reply #4 on: May 30, 2016, 10:14:59 AM »
Greetings. Everyone should own a 750 and a Harley.
Offline dusterdude
Re: 750 4
« Reply #5 on: May 30, 2016, 03:37:27 PM »
Damn straight
Sent from my LG-D850 using Tapatalk
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Re: 750 4
« Reply #6 on: May 31, 2016, 07:40:21 PM »
About that oil .It doesn't want to stay in the oil tank. When I first got it I drained out what was in the bottom of the cases and poured back into the oil bag. And added 1 quarts 20-50 Napa oil. Now it has all disappeared again. Here's a picture of my 750 and my 90 and my choppa.
Offline Johnie
Re: 750 4
« Reply #7 on: May 31, 2016, 07:46:37 PM »
There is a check value that is supposed to stop the oil from the oil tank running down into the crankcase. Very common for them to leak, but not a big deal. Just change the oil and add the correct amount of oil and you will be fine. Always check the oil level when hot as the oil will be in the tank, but as it sits it will drain back into the case. What usually happens is someone not familiar with this check valve issue will check the oil cold and find it low and will add oil which then overfills it. They run the bike and have oil gush out all over the back tire creating a very dangerous handling issue. A member on this board does make and sell the check valve in case you ever want to change it out.
« Last Edit: May 31, 2016, 07:48:28 PM by Johnie »
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Re: 750 4
« Reply #8 on: May 31, 2016, 08:48:29 PM »
How much of that castrol oil do I need to get ? Wheres the filter at ?
Offline Johnie
Re: 750 4
« Reply #9 on: June 01, 2016, 05:49:07 AM »
About 3.7 US quarts of 20w50 Castrol 4T cycle oil many of us use. The filter housing is on the lower front of the engine between exhaust pipes 2 & 3. Be really careful not to strip the filter bolt or you will be in bad shape. Use a 6 point socket if it is the small OEM bolt. Previous owners had a tendency to over tighten them. The filter is still available from Honda. You mentioned your oil tank is usually empty, but there is a drain bolt on the bottom of the oil tank which should be emptied when you change the oil too. Both the oil tank drain bolt and crankcase drain bolt should have a crush washer on.
« Last Edit: June 01, 2016, 05:54:30 AM by Johnie »
Oshkosh, WI  USA
Re: 750 4 check valve
« Reply #10 on: June 07, 2016, 06:36:53 PM »
I'd like to get in contact with the person making the new check valves. I have a really hard time starting a motor with no visible oil in the oil tank.
 Thanks,
 Weathervaneman.
Offline danyo
Re: 750 4
« Reply #11 on: June 07, 2016, 08:21:22 PM »
User Elan makes complete kit for oil pump.
Sent from my SM-N900T using Tapatalk
Offline TorqueAddict
Re: 750 4
« Reply #12 on: June 28, 2016, 06:37:12 PM »
Welcome!
« Reply #13 on: June 29, 2016, 05:12:34 AM »
 Thanks,
 Weathervaneman.
http://forums.sohc4.net/index.php?action=profile;u=19471
Welcome!
Re: 750 4
« Reply #14 on: June 29, 2016, 09:53:06 AM »
When you remove the oil filter there is also a thin washer next to the spring. It usually sticks to the filter and can be thrown out. Watch for it.
Offline Johnie
Re: 750 4
« Reply #15 on: June 29, 2016, 11:51:22 AM »
Jerry I bet that washer is long gone :)  I don't think I have ever found it in place on any of these bikes.
Oshkosh, WI  USA
