Author Topic: That was a lot more than I expected - 1978 CB750K  (Read 2580 times)
Offline gtacb750
« on: May 29, 2016, 12:51:45 PM »
Hello,
And welcome to my build thread. This thread is going to be a lot more catching up on what I've done so far but better late than never.
I bought my project bike with the intentions of turning it into something of a cafe/brat bike. What I wanted to get out of it was to learn as much as possible and increase my skill level of working on vehicles in general. I chose the cb750 platform since the aftermarket was strong and there was a lot of support for these bikes so if I ever got lost there probably was an answer out there. I had an older ninja 250 that I rode for a few years while in school but since working I sort of gave that up altogether. I'll be getting married this year and wanted to get this out of my system.
An opportunity came up in October/November 2015 and I picked up the bike right away. Here are a few pictures of it on the first day in the garage.
The story behind the bike is that it was purchased by the previous owner with no title and he had gotten the title himself. He bought it from a friend of the owner before that. The bike didn't have a battery, no oil in the engine, no brake fluid in the front m/c, fairly cruddy condition but it turned over. It was definitely a project bike..
cont...
« Last Edit: May 29, 2016, 01:02:33 PM by gtacb750 »
Re: That was a lot more than I expected - 1978 CB750K
« Reply #1 on: May 29, 2016, 01:58:18 PM »
Haha! LOL! Keep telling yourself that. Motorcycles are like crack!! In a good way!  ;D ;D ;D
Offline mystic_1
  • 1970 CB750K
« Reply #2 on: May 29, 2016, 02:41:18 PM »
wanted to get this out of into my system.
Fixed this for you.
cheers!
mystic_1
- John Augustus Shedd
Offline gtacb750
« Reply #3 on: May 29, 2016, 02:47:15 PM »
First step on this project was to strip down the bike to the bare frame. All parts were organized and stored away to be refurbished later on. Took me a few days but the weather was still on my side and it was a good opportunity to assess what was junk and what could be saved.
While doing all this I worked out my plan of attack. I'd rebuild the suspension bits and replace the wheel bearings and steering stem bearings first. Then move onto getting new tires on the bike. I wanted to get this bike rebuilt and on the road by spring 2016 (very ambitious).
Dry rotted tires and rusty spokes
I had to saw off the old tires
Laid out and cleaning up the hubs before installing new bearings
By this point I think it started getting cold in the garage...that made it interesting
tbc...
Offline gtacb750
« Reply #4 on: May 29, 2016, 02:50:06 PM »
Fixed this for you.
cheers!
mystic_1
Thanks for catching my misprint  ::)
Offline gtacb750
« Reply #5 on: May 29, 2016, 03:05:33 PM »
Part 3
I finished cleaning up the hubs and installing the bearings...
Next step was to tackle the swingarm bushing. To be completely honest, this was very tedious. The old plastic? bushing wouldn't budge. In the end I carefully used a saw blade and made a cut down the middle and eventually I could drive it out. Just took way too long.
The paint on the top triple bothered me so I got rid of it.
Along with the old paint on the gas tank.
It was around xmas and I decided I wanted a swept tail and bought a hoop off a guy locally.
Cuts were made (probably not the greatest) and time was spent. Tabs were also removed since I wanted to use velocity stacks in lieu of the stock airbox.
Also at some point during December I decided I absolutely had to paint my rims black. So that's what I did. It was a crappy paint job and i'll get it powdercoated later on but it'll do.
Christmas arrived and some parts came with it: Tires, levers, tubes, honda nuts and bolts. Anticipated engine rebuild tools etc.
Funny enough when the order from amazon arrived they shipped each item in a massive box. So I had 6 huge boxes at the door...lots of scrap cardboard to keep the table clean while I worked.
tbc..
Offline gtacb750
« Reply #6 on: May 29, 2016, 03:14:53 PM »
About the rear wheel. I didn't realize the k8 came with a 17 inch wheel and there aren't many affordable aftermarket solutions for this so I had to purchase the OEM spokes individually.
Anyways...here is my 3rd and final attempt at installing the spokes. Took me three tries to get it right and a bit of googling images of the wheels.
Wheels were trued..
And tires mounted..silly enough when installing the rear tire I punctured a hole in the tube and it wouldn't hold air. Frustrating..I had to purchase another tube and be extraaaa careful. End of the day it was fine.
New progressive springs were installed for the front fork and new oil as well. No pics since I forgot to take them.
So that wraps up the suspension and wheels! Progress!
Up next the engine...
« Last Edit: May 29, 2016, 03:16:55 PM by gtacb750 »
Offline mystic_1
  • 1970 CB750K
« Reply #7 on: May 29, 2016, 06:18:34 PM »
Looking good so far, looking forward to seeing where you went with it.
mystic_1
« Reply #8 on: May 29, 2016, 11:34:16 PM »
I like the F tank with the K8 frame.
Offline gtacb750
« Reply #9 on: May 30, 2016, 07:52:22 AM »
Im a fan of it as well. Prefer the earlier tanks though.
What surprised me was the capacity of the F tank. Almost 20 litres!
Offline gtacb750
« Reply #10 on: May 30, 2016, 05:27:26 PM »
So I knew that the engine turned over, It had developed an oil leak at the head gasket based on the old gummy oil on the front left side of the jugs and it was leaking oil at the stator cover if you kicked it over. The motor was the original motor with the bike and had ~35,000 km on the odometer. I had no idea of the condition of the top and bottom end and didn't want to risk running it in fear of it exploding or damaging anything in the bike. It must've been parked for a reason.
My plan of attack was to refurbish the top end with new piston rings and regrind the valves, new gaskets, hone the cylinders, install new studs and oil seals all around. I purchased the necessary tools and parts and got to work. Mind you…this was the dead of winter around late January/early February and I tried to do as much of the work as possible in the basement since my fingers and toes were freezing off in the garage.
Nothing was broken in the top end, camshaft appeared to be in good condition (based on my untrained eyes), rockers alright and valves unbent. Took my time and measured each part to ensure it was in good working order. Only issues I could find were that a few of the oil rings had too much gap but the new rings solved that and one new piston pin courtesy of Honda.
After a lot of scraping off the old gasket and cleaning the carbon off the piston, valves and combustion chamber this was what it looked like. Mating surfaces had acceptable straightness? Measured with a feeling gauge and straight edge of a ruler.
Now I was left with the bottom end and what to do with it. I had already come this far and it would probably be okay the way it was. But seeing as how my whole goal of this project was to get as deep into the bike as possible I split the cases to inspect all the parts and learnt how everything worked (in hindsight this was completely unnecessary after reading about how the bottom end for the most part was bullet proof especially if I believed the odometer to be true but nonetheless I did gain a lot of valuable information and confidence doing it). The studs were difficult to remove without a stud extractor. Double nutting only worked on a few studs, the rest I bent and twisted them out slowly – very unsettling experience. Removed the kick starter mechanism for some reason only to reinstall it after inspection and cleaning (such a pain).
Only thing I replaced in the bottom end was one green bearing as it had a slight scoring on it.
So after cleaning all the cases multiple times and extremely thoroughly I decided it was time to paint! I really liked what other members did with the black top end with aluminum fins and aluminum bottom end. So I painted the top end gloss black – looks slick. And bottom end aluminum with engine paint.
I was a lot more thorough in the prep and paint than I was for the rims. Call it a lesson learnt as I wasn't happy about my last painting results.
Once paint was done it was just a matter of putting aside a full day to tackle the reassembly. Putting the case halves together was tricky doing it alone and I had to fumble my way around with installing the pistons into the sleeves but after a lot of trial and error it went in without too much of a hassle.
Now that the engine work was out of the way it was time to tackle the frame.
By now it was mid March with not much left to do. I should be done by my deadline of spring and all I had to do was clean the carbs, clean and paint the frame, derust and paint the tank, install the wiring harness, coils plus electronics, polish my covers, install some cables and done! Off we go on a cross country road trip to California! Ya right…
Tbc
Offline djmaynard
« Reply #11 on: May 30, 2016, 07:33:49 PM »
Love reading this! I am in the process of rebuilding a 82 cb900c and this gets me going again!!
« Reply #12 on: May 30, 2016, 09:50:32 PM »
Wow, that motor came out great.  That was a lot more than I expected, too!
Offline gtacb750
« Reply #13 on: May 31, 2016, 08:51:48 AM »
Thanks for the compliment. I really enjoy reading other peoples build threads.
Quite pleased with the outcome. Next time around I want to try vapour blasting it. I felt like the engine rebuild was a labour of love. A great confidence booster...
Offline gtacb750
« Reply #14 on: May 31, 2016, 08:18:54 PM »
The condition of the frame for the most part was in fairly good condition. There was slight surface rust in certain areas on the frame but not major. I had a friend come over and help me out. Doing everything on my own was very time consuming and progress was hard fought. So he offered another set of hands.
The frame had all the grime cleaned off and sanded down. Then shot on a few coats of roll bar paint after reading others having some success with it. All in all the paint turned out okay. I had to let it sit for a week to harden before I was comfortable moving it around. I threw some rocks at it just to see if it would chip - nope. Next time around i'll get it powdercoated though.
First that I did was slap on the front and rear wheels along with the gas tank to get an idea of what it all looked like. Sweet satisfaction....
And with a couple hours free one evening the engine was installed
Now I had wanted to work on getting rid of the rust in the gas tank. You could scrape it off with your finger on the inside and if you shook it up flakes of rust would come out.
My first attempt I bought white vinegar from walmart and filled the tank to the top. After a few days you could rub off the rust and would be left with bare metal afterwards. When draining it and rinsing with a mix of baking soda and water i'm not sure what I did wrong but it would flash rust extremely quickly. I poured some ATF and diesel fuel into it and sloshed it around thinking it would help. Nope.
Second round I tried it again with the vinegar thinking i'd use fogging oil instead. Stupid me, I didn't degrease it before pouring in the vinegar and it just made a mess of things and the rust came back even worse than before. I almost gave up and started calling around for quotes to have it professionally done. Locally it would've cost about $200 to derust and line it. For some reason I didn't like the attitude I got from the guy over the phone so I tried a third round.
Woke up early on a Sunday morning and spent an hour at home depot reading product labels trying to find something that would help. I had read that in the states you could buy fairly inexpensive products with phosphoric acid which was very effective. Nothing like that up in Canada. I used a cheap $3 home depot brand toilet bowl cleaner (hydrochloric acid) and bought something called KrudCutter?? (phosphoric acid) for $12 to use. I soaked the tank in the toilet bowl cleaner and shook it around periodically. Within 20 minutes or so it was spotless. I drained it and carefully flushed it with baking soda and water and immediately blew the inside with the compressor to remove as much water as possible after a sloshing with acetone. Worked amazing! Then used the KrudCutter as insurance. After 2 hours of frantically working here was the result.
I wasn't sure what direction to go with the colour scheme of the tank but it was going to be a budget paint job. After reading up on the rustoleum paint job I figured I'd give that a try. Colour was going to be an aluminum colour. The exterior condition of the tank wasn't great. It needed quite a bit of bondo work as it had quite a few dings from the bike being dropped and also It was off not centered anymore and a bit off alignment. But it'll work.
Here is a picture of the headlight bucket and tank after priming to mock up on the bike.
I don't have a picture of the gas tank after painting aside for on the bike later into the project so i'll share that afterwards.
Also worthwhile to mention I spent a few evenings sanding, cleaning and polishing the side covers. I didn't get them to a perfect mirror reflection but good enough for me.
Now onto the electrical...
« Last Edit: May 31, 2016, 08:34:05 PM by gtacb750 »
« Reply #15 on: June 01, 2016, 09:27:13 AM »
It looks like you will be using a solo seat (with the upturned hoop and F tank).  If so, are you going to keep the passenger peg mounts?  I kept mine since they provide a mount point on the right side for my exhaust.
Offline gtacb750
« Reply #16 on: June 01, 2016, 11:59:03 AM »
I will be using a two up seat. Made my own seat pan, did the foaming and sewing myself. Not great but a good first attempt I think. The seat build will be coming up in a future post. I semi-tested the two up seat with me and the fiance on the back and it's a bit tight but oh well. At some point i'll make a solo seat with a cafe hump to swap between the two up seat depending on my mood.
I kept my passenger pegs so my passenger has a place to put their feet :)
« Reply #17 on: June 01, 2016, 12:16:00 PM »
No kidding?  ;)  I can't remember the build, but someone did a convertible seat with a removable cowl (to cover the passenger seat).  Not the easiest thing to pull off.  The swappable seat option sounds much easier.
Offline gtacb750
« Reply #18 on: June 01, 2016, 12:20:55 PM »
I was thinking something along those lines as well but the fitment of my seat pan isn't dead on so just make another. I used some stainless steel that was laying around outside the house. It is much thicker than necessary but I didn't have to buy it. Next time around i'm going to try using fiberglass since it'll fit the contours of the frame much nicer.
« Reply #19 on: June 01, 2016, 12:43:46 PM »
I would suggest metal (either regular sheet steel or preferably aluminum) over fiberglass.  Over time, fiberglass is less durable (dries out from exposure) and can chip or crack.
Offline gtacb750
« Reply #20 on: June 01, 2016, 02:51:40 PM »
Probably aluminum then. We will see how ambitious I am by that point. If i get a MIG welder i will probably try it in steel. It will be tough to form the rear hump though...good excuse to mess around in the garage.
