Author Topic: Tire issue fixed, now squeaky brakes  (Read 351 times)
Offline mex3000
« on: May 30, 2016, 01:45:46 PM »
As some of you may remember,  i had a new front tire put on a few weeks ago, and when I picked it up,  I had the front fender rubbing on the new tire, and lots of vibration around 35-40mph. Took iy back to my mechanic, got that fixed, but now the darn front brakes sqeak all the time. The noise goes away when I apply the brakes. Truly sucks because i never had this before,  and it's embarrassing when riding at slow speeds, and people hear that #$%*. Any advice on how I can fix this myself without having to take it back to my mechanic. I'm not mechanically inclined, so all help is appreciated.  Thanks
Sent from my SM-N920T using Tapatalk
Offline CycleRanger
  • No comment about being an
Re: Tire issue fixed, now squeaky brakes
« Reply #1 on: May 30, 2016, 02:02:16 PM »
You just need to adjust the caliper alignment-to-the disc sounds like. Just need a flathead screwdriver. Easy to do.
Hopefully that's the issue and not a misaligned pad in the caliper.
Offline mex3000
« Reply #2 on: May 30, 2016, 04:04:20 PM »
I went ahead and turn it a bit counterclockwise,  and adjusted the nut. The squeak has minimized,  but now increases when i lightly pull the brake, and goes away at full pull.
