Author Topic: 3rd Gear Chop  (Read 720 times)
Offline 550Resto
3rd Gear Chop
« on: May 31, 2016, 03:03:36 PM »
I wanted to get some expert opinions. I attempted to perform a plug chop in 3rd gear full throttle. The plugs haven't had to many miles on them. I'd say less than 50 since bringing her back to life. I wanted to see what if any thing I should do in the way of richen or leaning. I've got stock airbox and a 4into1 delkevic exhaust. Carbs are stock as well with I believe 90 mains and 38 slows.
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
Re: 3rd Gear Chop
« Reply #1 on: May 31, 2016, 03:31:09 PM »
#2 looks to been slightly leaner than the other 3.  Maybe a 1/8 turn out and that's all I'd do!
Cause your plugs look very normal.
Offline CB650CPastor
Re: 3rd Gear Chop
« Reply #2 on: May 31, 2016, 07:33:46 PM »
Plug pictures should be in a well-lit area, without flash, and with all four plugs in the same pic. Differences in distance from one pic to another along with a flash that washes out the pics makes it pretty hard to read plugs. Don't shoot the messenger.
Tim
Current:1980 Honda CB650C Custom, 1969 Toyota Corona Deluxe Sedan
Past: '07 Honda Rebel 250, '80 Yamaha XS1100 Special, '69 Honda CB160, '67 K15 Suzuki Hillbilly, 1971 VW Super Beetle...
Offline Powderman
Re: 3rd Gear Chop
« Reply #3 on: May 31, 2016, 07:35:12 PM »
From the lighting of that pic they all look too lean. They should be a light tan color if running correctly.
How many miles are you putting on it before doing the chop?
« Last Edit: May 31, 2016, 07:36:51 PM by Powderman »
Re: 3rd Gear Chop
« Reply #4 on: May 31, 2016, 09:10:05 PM »
Lean, across the board.
Install 100 mains and retest.  Dont make any other changes.  (its only .10 mm bigger)
The thing to remember about WOT plug chops.  If you plan to spend a LOT of time at WOT, then get it perfect. Light tan plugs.
If only on occasion when opportunity arises, then just get it close....and by close, i mean be on the rich side.
It'll make tuning needle position that much easier.
  • Holy Cow! I'm a
Re: 3rd Gear Chop
« Reply #5 on: May 31, 2016, 09:40:58 PM »
Guess I was off a bit.
