Author Topic: Bought some turn signals off ebay - two wires neither black  (Read 1024 times)
Offline ChopSticks
So I bought a couple of front LED turn signals off ebay for my sportster and it only came with 2 wires (sportsters come stock with 3 wires due to double filament bulbs (ground, running, turn)
I understand that the LEDs are only ground and turn but I can't figure out which is ground, the two wires are blue and green. Is there anyway to test which is the ground or will it be safe to directly hook up to a battery and find out?
Offline calj737
  • I refuse...
Re: Bought some turn signals off ebay - two wires neither black
« Reply #1 on: June 01, 2016, 07:42:10 PM »
Hook to a battery directly. Most LEDs have no polarity. You'll know immediately if they do as they won't light.
Offline zammykoo
    • @Mototam
« Reply #2 on: June 02, 2016, 05:14:53 AM »
Yep, it won't damage the LEDs by hooking directly to battery to test.
Offline ChopSticks
« Reply #3 on: June 02, 2016, 06:31:02 PM »
THANKS! worked like a charm, green is ground if you guys were wondering  ;D
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #4 on: June 16, 2016, 06:49:29 PM »
Green for grass and grass grows on the ground!
Least that's how my pops used to explain it to me.
