Author Topic: Motorhanger bolts  (Read 1246 times)
Offline beemerbum
Motorhanger bolts
« on: June 03, 2016, 07:30:42 PM »
Does any one know the lenghts of the four long bolts that hold in the motor? I have a handful of long bolts and no bike or frame handy to compare them to. Thanks in advance. BTW, CB 750., K1 I believe.
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
Re: Motorhanger bolts
« Reply #1 on: June 03, 2016, 07:56:54 PM »
Hardware sizes are usually mentioned in the parts list.  Find the fiche and you'll get the right answers ;)
« Reply #2 on: June 03, 2016, 11:14:47 PM »
Measure your old bolts? 3 long bolts....
I ordered a set of 3 new complete bolts with washers and nuts. So easy to mount the engine this time, the original ones have banana shape that made the assembly to a real pain.
The threads are fine so nuts a must since I do not have fine threaded nuts in my boxes.
http://www.ebay.de/itm/291318970546?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
This indicate the the bolts are same for all Kx models
http://www.ebay.de/itm/Honda-CB750-CB-750-Four-sandcast-1969-1978-engine-bolt-set-new-/290509702512?hash=item43a3ba4570
EDIT: Just for sure...lenghts in mm described in the link. Not fine threads will most likely not work that well
1x Schraube (C) verzinkt M10x1,25x280 SW17 inkl. Sprengring, Scheibe und Mutter
1x Schraube (A) verzinkt M10x1,25x315 SW17 inkl. Sprengring, Scheibe und Mutter
1 x Gewindestange verzinkt M12x1,25x365 inkl. 2 Scheiben und Muttern
Honda Vergleichs-Teilenummern: 90156-300-000 + 90152-300-010 + 90155-300-000.
« Last Edit: June 04, 2016, 01:32:03 AM by PeWe »
Offline beemerbum
« Reply #3 on: June 04, 2016, 07:52:15 AM »
Danke
