Author Topic: RE: CB400f What kinda of speed to expect?  (Read 3880 times)
Offline chewbacca5000
  • I polish covers!
« on: June 04, 2016, 05:45:00 PM »
First time out on my 400f today about 10 miles and am still in the process of "waking her" up after a 6 year nap.  Wondering what kind of speed I should expect?  Bike shows 50k on the clock.
Floats are set to 22mm
Air screews are 1 1/2 turns
Offline jonda500
Re: RE: CB400f What kinda of speed to expect?
« Reply #1 on: June 04, 2016, 06:55:52 PM »
I would expect it to be able to hit 100mph.
Also usually there's a flat spot at around 5000rpm that you need to get the revs past.
John
A starter clutch thread:
Offline MoMo
  • Ride like you're invisible
« Reply #2 on: June 04, 2016, 08:03:44 PM »
100 downhill with a wind behind you as it was rated 95mph
Offline Scott S
« Reply #3 on: June 05, 2016, 05:57:44 AM »
 You mean it won't do 85 in 2nd gear?! ;)
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline dhall57
« Reply #4 on: June 05, 2016, 06:06:34 AM »
I bet Chew hasn't done his 3000 mile tune-up yet. Being a 400 he might be able to hit 90 in 2nd ::)
« Last Edit: June 05, 2016, 06:08:33 AM by dhall57 »
1970 CB750KO
1971 CB500KO-project bike
1973 CB350G- project bike
1974 CB750K4-project bike
1974 CB750K4
1976 CB750K6
1977 GL1000
1997 Harley Wideglide
Offline flatlander
« Reply #5 on: June 05, 2016, 07:34:40 AM »
my neighbour has a 400f. when she left once for a couple of weeks she dropped me the keys, saying: go give it a go if you like. of course i could not resist... on the highway i found myself mostly in the right hand lane (with my 550 i'm mostly on the far left...), keeping up with traffic up to around 120 - 130kph (80mph). once it was there it kept rolling but it took a while to get up to that speed, and lost responsiveness considerably as it was getting close to its limit. overtaking was a chore, had to be planned quite carefully.
it seemed pretty happy with still a bit reserve left when going at around 100kph (+/- 65mph). nice for smaller roads but on the highway i felt a bit like on a moped.
i measured these speeds on the gps, not the speedo so they should be quite realistic.
95 mph is the quoted max speed? you may be able to reach that if you don't have a stiff wind against you, but make sure you take some packed lunch coz it will take some time ;)
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=amh50f14m5mehbk1mjkdro91p1&/topic,60973.0.html
« Reply #6 on: June 05, 2016, 07:50:04 AM »
mine can hardly get over 100 kmh..but think i have a problem ..those carbs is making me mad..one is floting and oner is drying.
i hate all this v-w.... vords
Offline flatlander
« Reply #7 on: June 05, 2016, 08:07:32 AM »
it should definitely go over 100kph. it won't do it very quickly but it'll get there. my neighbour's 400 is totally stock and not too well maintained.
Offline strynboen
« Reply #8 on: June 05, 2016, 08:10:46 AM »
i think i thange to rubber needels in the fuel valvets..or try to tap them carefull to seat better...its a float heigh problem
Offline flatlander
« Reply #9 on: June 05, 2016, 08:20:14 AM »
good luck! hope you get it to run right. they're fun bikes, just not for longer runs on the highway.
Offline Deltarider
« Reply #10 on: June 05, 2016, 08:45:40 AM »
Wouldn't say that. A friend went all the way to (and in) Morocco on a CB400 Four.
CB500K2-ED Excel black
  • I polish covers!
« Reply #11 on: June 05, 2016, 09:31:58 AM »
Yup I have not given it the 3,000 mile tune up yet.  Adjusted the cam chain and set carbs to 22mm.  Will adjust the valves and set the timing.
For some reason I was thinking it would be able to pull just as hard as my K1.  I will see if I can get in  a bit better tune.
Offline Tim2005
« Reply #12 on: June 05, 2016, 10:07:27 AM »
Just over 100 on the speedo if it is in top condition and set up really well, or you have a tailwind/downhill, but realistically 90-95 is what I'd expect from a decent one in normal circumstances.
Offline nvr2old
« Reply #13 on: June 05, 2016, 10:11:29 AM »
My '75 400F runs like a top, and will do 95-98mph full-out.  It'll cruise at 75-80, but likes 70mph best of all.
'76 CB550F-'72 XL250-'82 MB5-'82 CX500 Turbo-'77 naked Goldwing-'75 CB400F cafe'-'79 Suzuki GS1000S..hey, it's a Wes Cooley..
  • I polish covers!
« Reply #14 on: June 05, 2016, 01:13:34 PM »
I checked the timing and it had an after market plate and points.  I replaced it with a TEC and both 1,4 and 2,3 are spot on for the timing.
It had a jitter before.  Much better now.
Sure there will be a few more surprises like the missing o-ring on the float bowl drain srews for 1,4.  Peed all over me guess that is part of the joy.
Bike sounds good.
Pipe is a little louder than what I expected.  I this normal for the 400f?
  • I polish covers!
« Reply #15 on: June 05, 2016, 05:49:29 PM »
Got the TEC points set and it could tell right away it made a difference.  Bike runs like it should.  Takes some getting used to having to do all that shifting since the bike seems to only really accelerate fast when the RPMs are up there 7,000+
Offline MoMo
« Reply #16 on: June 05, 2016, 05:51:36 PM »
exhaust is quiet, sure you have stock?
  • I polish covers!
« Reply #17 on: June 05, 2016, 06:05:57 PM »
No exhaust is louder than I expected.  I think this video explains my disappointment quite well.  This is a guy I know local who is a professional mechanic and has a couple 400fs.
If you watch this video he is doing about 90 mph and the RPMs are close to 10,000.  Lots of downshifting to keep the rpms up too.
Offline MoMo
« Reply #18 on: June 05, 2016, 06:24:36 PM »
If they're doing 90 they look like candidates for future road kill....Larry
  • I polish covers!
« Reply #19 on: June 05, 2016, 06:30:29 PM »
You could be right about that one...
Offline Scott S
« Reply #20 on: June 05, 2016, 06:57:03 PM »
 Damn.....and the 250 still walked away from him!
'71 CB500 K0
'81 Yamaha XS650
Offline camelman
  • Man... Myth... Legend
« Reply #21 on: June 05, 2016, 08:12:46 PM »
That 400f in the video seems to run as I'd expect. Against a 250 2-stroke it could lose in a drag race, but we also don't know if the 250 had a jump on the 400 and came from behind it after a longer acceleration period. The handling issues of those old 2-strokes looked pretty apparent in that video though. :)
My last 400f had a 466 kit and bored out carbs. It was faster than my friend's 550 with a 650 cam and would easily blast past 100mph. That 466 kit completely transforms those 400s when paired with bigger, or bored out, carbs.
1972 350f rider: sold
1972 350f/466f cafe: for sale
1977 CB400f cafe:sold
1975 CB400f rider: sold
Offline flatlander
« Reply #22 on: June 06, 2016, 12:13:14 AM »
sure it can be done. still, on a dutch or even german highway they would not be my ride of choice.
Offline strynboen
« Reply #23 on: June 06, 2016, 02:19:56 AM »
sai"d it this vay.
..400 is a super fine looking and driving bike..
.but the 500/550 have just the power and stabillity,,for better heighvay performance(not perfekt..just better)it can easy go 160 mph..as a stock bike(good tune)
 the 400 is missing a bit.against it..(.like the 550 miss a bit against the 750)
.to be the perfekt Honda sohc
.the 400 just not have power..and the frame/hveels/evrything... is a bit smaller..and need rpm to delevery power
..i have both..so dont have to those one over the other..vill be a hell to let one go...
the perfekt bike vas a styling of the 400 6 gear..amd 550 frame engine and 750 cc in
« Last Edit: June 06, 2016, 02:38:21 AM by strynboen »
Offline flatlander
« Reply #24 on: June 06, 2016, 03:03:27 AM »
 :o
that is pretty good for a stock bike from the 1970s!
mine must be in crappy tune as it does that number in kph ;)
