Author Topic: RE: CB400f What kinda of speed to expect?  (Read 3871 times)
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=c383efj8n9h9uq0v8g2c4jt3v6&/topic,60973.0.html
Re: RE: CB400f What kinda of speed to expect?
« Reply #25 on: June 06, 2016, 03:50:11 AM »
it can easy go 160 mph..as a stock bike(good tune)
 :o
that is pretty good for a stock bike from the 1970s!
mine must be in crappy tune as it does that number in kph ;)
oh damed ...i mean 160 kmh....its my cbx vho does that
i hate all this v-w.... vords
Offline chewbacca5000
  • I polish covers!
« Reply #26 on: June 06, 2016, 03:18:19 PM »
Took her for another spin and after 100 miles the bike seems to have woke up a bit.  It does make power if you drive it like a small 6 speed keeping the revs high.
I am not as confident on th 400f in traffic as my 750, but my 750 has had everything replaced.
Offline Tim2005
« Reply #27 on: June 06, 2016, 04:08:30 PM »
Yes they do need revs- best to try to keep them above 6000 and then the fun begins.
Offline camelman
  • Man... Myth... Legend
« Reply #28 on: June 06, 2016, 04:17:06 PM »
Some of what you are experiencing is likely the stability of the bike even though it first seems like it's power-related. Improvements in the front end will make the low power less of a factor, and make the bike more comfortable and confidence-inspiring on the highway.
A more modern front end makes a phenomenal difference in comfort at speed. An alternate, and easier, option is to improve the existing front end. The original bearings are usually shot by now, and are fairly easily swapped. Swapping in an aluminum lower triple tree will yield HUGE handling and stability benefits over the stock lower since that stock lower flexes like mad. Swapping the upper triple won't yield much benefit. Fresh fork oil and appropriate springs makes a difference too. There's also the rear end to address, but I bet the front end is where you'll see the biggest difference.
1972 350f rider: sold
1972 350f/466f cafe: for sale
1977 CB400f cafe:sold
1975 CB400f rider: sold
Offline jonda500
« Reply #29 on: June 07, 2016, 05:18:06 AM »
Remember the indicated speed is typically eight percent higher than the actual speed!
John
A starter clutch thread:
Offline flatlander
« Reply #30 on: June 07, 2016, 06:20:31 AM »
that's why i said that my speeds were measured with a gps unit. the speedo showed something more optimistic.
on my 550, the speedo shows something between 115 and 120kph when the gps says 103 or so. i remember this because that's how i get through the 100kph average speed zones ;)
