Author Topic: SOLVED! Re-keying seat lock and/or finding a matching lock?  (Read 2058 times)
Offline mkcman17
Purchased my 550f in pieces and it was missing a seat lock. The bike is really coming together now and I'm at the point that i'd like to get myself to one key for the bike. The ignition and tank match. The key reads H22 and the ignition is stamped 110224H22 or 110234H22 - one number is partially obscured by the fork lock pin. Nothing shows up on my searches...
Is it possible to remove and match the wafers in the seat lock (i've done this once before when replacing a car door lock) or is there a better key code I can keep an eye out for online?
TIA
Mike
Before and after for reference:
« Last Edit: June 08, 2016, 07:18:26 PM by mkcman17 »
'75 CB550F
Offline CycleRanger
  • No comment about being an
Re: Re-keying seat lock and/or finding a matching lock?
« Reply #1 on: June 08, 2016, 12:03:36 AM »
check with this guy.
http://www.hondakeys.com/
I've also gotten pre-cut keys from ebay too.
Offline mkcman17
« Reply #2 on: June 08, 2016, 12:23:31 AM »
Thanks for the reply, maybe I wasn't clear - I have keys but I'm looking for a way to math the seat lock and/or source a matching seat lock. Currently I'm carrying two different keys for the bike.
'75 CB550F
Offline CycleRanger
« Reply #3 on: June 08, 2016, 12:40:17 AM »
Sorry, it's late. :)
I have the same problem with my K5. The ignition was changed sometime.
The locks are pretty easy to re-key but I have no idea who would have the parts.
Probably easier to just buy a new lock set.
« Last Edit: June 08, 2016, 07:50:25 AM by CycleRanger »
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #4 on: June 08, 2016, 02:35:07 AM »
Nice bike
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=d3kdvh1b6cf7gval76s06etb20&/topic,60973.0.html
« Reply #5 on: June 08, 2016, 03:32:55 AM »
normaly there is a 4 number code on the Lock itself..i have just faund some ekstra keeys at e bay for my 400 four..
it have the code t -1927..the t stands for the auter form of the key.( thange a bit in the years  modells).there is only10-20 kodes,,so easy to find a match key...or a matck Lock... must the same vay..find the code on the bike ...and seargh on e bay for a match..but try to find the 4 siffer code
i hate all this v-w.... vords
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #6 on: June 08, 2016, 04:13:34 AM »
I'm pretty sure the tank locks that were used with the fuel door tanks are a pseudo lock, i.e. just about anything flat enough to insert and firm enough to turn will open the tank. It only looks like a lock.
The same thing can be done to the seat lock. Open it up and remove the little brass pins and springs to make the seat lock function as a pseudo lock as well.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #7 on: June 08, 2016, 05:30:14 AM »
I am sure you can re-key it, I done it with F igniton lock, wasnt that hard.
Offline strynboen
« Reply #8 on: June 08, 2016, 07:08:34 AM »
the seat Lock is a" real" one..its only the tank Lock vho are a bit "flimsy"
Offline mkcman17
« Reply #9 on: June 08, 2016, 05:35:19 PM »
My seat lock has a 5-digit code and I found a loose key on Ebay. The only lead I have on a master key is H22 (on both key and ign), or '110224' stamped across the fork lock pin on the back-facing side of the ignition assembly. internet searches have yielded nothing for either combination.
This actually brings up a pretty good point...if I can get the cylinder out I can probably remove the wafers altogether and turn it into a dummy-lock. I only keep some tools and a bungee under the seat and I take my helmet with me. This may be an acceptable solution for me.
'75 CB550F
Offline mkcman17
Re: SOLVED! Re-keying seat lock and/or finding a matching lock?
« Reply #10 on: June 08, 2016, 07:23:17 PM »
Took a stab at it, took apart a spare seat lock assembly I had that was missing a key for practice - setup the wafers by eye and it works great! Didn't even have to omit any wafers, just rearranged them appropriately.
« Last Edit: June 08, 2016, 07:36:28 PM by mkcman17 »
'75 CB550F
Offline CycleRanger
« Reply #11 on: June 08, 2016, 08:16:42 PM »
I had that same thought. Good job! :)
Offline mkcman17
« Reply #12 on: June 08, 2016, 08:53:46 PM »
Thanks! Never been so happy about such a little thing!
'75 CB550F
Offline jonda500
« Reply #13 on: June 09, 2016, 02:51:55 AM »
Well done!
That's very clever,
certainly much better than repeatedly ramming a drill into the key slot till the tumblers fell out! (which i did to one of my seat locks) John
A starter clutch thread:
« Reply #14 on: June 09, 2016, 08:34:18 AM »
So you rearranged the existing 'wafers' to fit your key and now it is a working keyed lock?
Offline SKTP
« Reply #15 on: June 09, 2016, 10:24:29 AM »
this is a cool idea....I have 2 keys for my bike (relocated under-tank ignition and the original 78K seat lock)...might have to try this...my 2 keys are fairly different, I wonder if it would work?
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
« Reply #16 on: June 09, 2016, 10:59:58 AM »
As long as the profile - aka cross section -  of the key is the same you should be able to do it.
Offline strynboen
« Reply #17 on: June 09, 2016, 11:05:11 AM »
they do thange over years modells..so dont think(not for shure/edit) all 750 keys can be codet to fit all model years..but give it a try..
« Last Edit: June 09, 2016, 12:23:16 PM by strynboen »
Offline CycleRanger
« Reply #18 on: June 09, 2016, 11:38:47 AM »
I've cleaned/rebuilt a few different locks and it looked like regardless of the key shape the "tumblers" looked the same.
Offline mkcman17
« Reply #19 on: June 09, 2016, 02:26:21 PM »
Yes. Funny enough, the front three positions were exactly the same between both keys - if I had left it at that I would have been able to use either key to unlock the seat. The last two I swapped to match, however I had to move one of the 'lower' wafers back one more slot.
It looks to me like there are only two types of wafers - for high and low ridges on the key. I held the key alongside the cylinder and 'eyeballed' the ups and downs. At worst, you can just arrange whichever ones work, even if only two or three, and have a lock work for your key (and potentially some others).
'75 CB550F
« Reply #20 on: June 09, 2016, 04:09:17 PM »
Car locks are not the most precise or sophisticated.
But I seen Volvo key the other day - pretty impressive. I file my own keys for Honda or Jeep but I would be lost trying to do the same for Volvo.
